Creating N links using a For Loop in Xacro
asked 2014-08-20 05:00:02 -0600
Zamzami gravatar image
updated 2014-08-20 06:51:31 -0600
I wonder if it is possible to construct a for loop to build N wheels sub-assemblies for a mobile robot in a xacro.urdf file.
I have already created an URDF using Xacro for the mobile robot and the wheel sub-assembly but I need to generate N wheels on each side of the mobile robot.
Any ideas, turnarounds or out-of-the-box solutions?
Thanks,
2
answered 2014-09-02 16:12:35 -0600
scpeters gravatar image
updated 2014-09-02 16:14:00 -0600
An alternative to xacro with urdf is to use SDF with embedded ruby (see the rigid_cart model for an example).
Use the following command to generate the sdf file from the rsdf template:
erb model.rsdf > model.sdf
Thank you scpeters, i'm not familiar with ruby but it seems to be an efficient turnaround solution and merits the effort.
Zamzami gravatar imageZamzami ( 2014-09-03 05:56:58 -0600 )edit
answered 2017-02-04 11:03:36 -0600
benelot gravatar image
If you have an if statement and you can call a macro within itself, you can build recursion with a counter which breaks the recursion as it reaches zero.
<xacro:macro name="loop" params="links_qty">
    <!-- call some macros or do other things -->
    <xacro:if value="${links_qty}">
        <xacro:loop links_qty="${links_qty-1}" />
    </xacro:if>
</xacro:macro>
<xacro:loop links_qty="15" />
I just tested if this works and it does.
answered 2014-08-27 06:36:20 -0600
Airuno2L gravatar image
To my knowledge, "if" statements are the only logic expressions currently implemented in xacro. I think having a wheel macro and using a single line for each wheel is the best you can do using just xacro, which isn't too bad.
Can you explain the reason you need this capability? If I really had to have something like this, I would probably attempt to use python to generate the single line macro calls and insert them into the xacro file.
I need to model a vehicle with infinite number of contact points (straight line) on each side of the vehicle. xacro's capability of a single line per wheel is nice but i don't think it will be efficient enough for creating hundreds of wheels.
Zamzami gravatar imageZamzami ( 2014-09-03 05:51:00 -0600 )edit
You can use ERB with SDF. ERB gives you a complete programming language in which to specify a model. See scpeters reply above for an example.
nkoenig gravatar imagenkoenig ( 2014-09-03 11:20:29 -0600 )edit
Asked: 2014-08-20 05:00:02 -0600
Seen: 2,052 times
Last updated: Feb 04 '17
