Create a Box Using Gazebo API
asked 2014-08-27 09:36:18 -0500
Eduardo Albuquerque gravatar image
How do I use Gazebo API to create a model? I want to implement a world plugin that creates a box with its size defined by a custom message, but I cant find any example of how to create a model using Gazebo API
Thanks for the help
Eduardo
answered 2014-08-27 10:52:31 -0500
nkoenig gravatar image
There is code in gazebo/gui/BoxMaker that you can use.
The BoxMaker class creates an SDF for a box, and sends the SDF string in a factory message on the ~/factory topic. You should also look at BoxMaker's parent class EntityMaker.
Thanks for your advice! That will be useful! That's a good starting point. Actually, I'm trying to implement a Remote Client for creating/modifying models (e.g. a robotic arm) dynamically. Can I use the API for add/modifying links and joints in a model that I created before. If I do, is there any sample code? If I can't, I'm thinking about modifying the model SDF description and reload it in the world every time the user modifies the model.
Eduardo Albuquerque gravatar imageEduardo Albuquerque ( 2014-08-27 12:41:01 -0500 )edit
Editing an existing model as you have described is not recommended. Try removing the current model, and add a new model.
nkoenig gravatar imagenkoenig ( 2014-08-28 11:53:41 -0500 )edit
Asked: 2014-08-27 09:36:18 -0500
Seen: 199 times
Last updated: Aug 27 '14
