gazebo 1.9.1 : openni_kinect plugin does NOT refresh cabinet(-like) objects when move manually
asked 2014-08-28 10:21:49 -0500
Enrique gravatar image
I have a world where I move cabinet or similar objects (they have wood texture) and the gazeborosopenni_kinect driver doesn't refresh the data. It keeps seeing them even if they're no longer there in gazebo, when I point with the sensor to their old location.
This doesn't happen if I use the regular cube object.
You can see a video showing this issue here: http://youtu.be/wuyAfVP8Ohk
I'm using gazebo 1.9.1 and ros-hydro.
I haven't try, but I guess this also happens with the gazeborosdepth_camera plugin.
answered 2014-08-28 10:56:33 -0500
Solved!
The problem was that the objects (cabinets, bookshelves, tables) where static in the world: <static>1</static>
Changing that to <static>0</static> has solved the problem.
Asked: 2014-08-28 10:21:49 -0500
Seen: 168 times
Last updated: Aug 28 '14
