gzsdf: command not found with Gazebo 4.0.2 on Ubuntu 14.04
asked 2014-10-02 12:10:47 -0600
NickDP gravatar image
Hi
I'm running Gazebo 4.0.2 on Ubuntu 14.04. I installed Gazebo with the one-line command given here.
I have a URDF file that I want to load in Gazebo. This file is given to me by somebody else and I don't have ROS installed. Following this tutorial, I want to use gzsdf to convert the URDF file to SDF.
However, when I try to run gzsdf, the command is not found. I also can't find the binary in my file system. Where should it be located? What do I need to do to get it?
Thanks
answered 2014-10-02 17:26:19 -0600
updated 2014-10-03 11:15:52 -0600
I found that the binary gz has a command sdf, which does what gzsdf is described to do. So the command
gzsdf print MODEL.urdf
as given in the tutorial is now
gz sdf -p MODEL.urdf
Is this a recent change? This should probably be changed in the tutorial then?
Asked: 2014-10-02 12:10:47 -0600
Seen: 6,234 times
Last updated: Oct 03 '14
