Parallel Robots - Implementing close kinematic chains
asked 2014-10-27 13:44:33 -0600
As I saw there is no official way for simulating close kinematic chains using URDF/SDF and gazebo.
2 questions:
  1. For a simple 4 arm mechanism: Will gazebo spawn an SDF with 4 Links and 4 joints forming this type of mechanism?
  2. If not, what is the right way of doing it?
Any direction would help.
Thanks
Nir
Hi..i am a new user here. In my case several linear actuators are applying forces to the same joint in parallel - some of them spanning only one joint, some even two joints.As Gazebo7 features a graphical interface, is it possible to create those closed chains graphically?
NoellEagan gravatar imageNoellEagan ( 2017-10-12 13:31:45 -0600 )edit
answered 2014-10-29 15:36:03 -0600
Closed kinematic chains are not officially supported with URDF, though they are supported with SDF. Here is an example of an SDF model with closed chain. Also, the PR2 gripper has a 4-bar linkage.
We are planning to create a unit test for closed chains, but haven't done it yet.
answered 2017-07-03 15:16:41 -0600
Duckfrost gravatar image
updated 2017-10-09 04:47:09 -0600
Building on what is already said, I created a Tutorial on Simple Closed Kinematics Model . Its just to have a starting point for anyone that is interested. It certainly helped me to understand it better and work afterwards on the fantastic tracksdriveplugin and my own projects .
image description
Here I leave you all the files I used, bith open and closed models sdf, their spawn launch files and the spawn sdf launch file:
simple_open_chain.sdf
open_chain_spawn.launch
simple_closed_chain.sdf
spawn_closekinem_example.launch
spawn_sdf_robotdesc.launch
You should be able to have something like this:
Hope this is usefull.
answered 2016-02-04 09:32:49 -0600
sts gravatar image
Hi, I'm considering the same thing. In my case several linear actuators are applying forces to the same joint in parallel - some of them spanning only one joint, some even two joints.
As Gazebo7 features a graphical interface, is it possible to create those closed chains graphically? Are the physics engines able to calculate valid solutions?
Thanks!
This sounds like a new question, not an answer. It would be nice if you could repost it as a question.
chapulina gravatar imagechapulina ( 2016-02-04 10:42:04 -0600 )edit
Asked: 2014-10-27 13:44:33 -0600
Seen: 2,394 times
Last updated: Oct 09 '17
