<gazebo/gui/GuiPlugin.hh> is missed?
asked 2014-10-28 21:11:21 -0500
BenWashburn gravatar image
When I built the source file from GUI Overlay tutorial, there was a fetal error that <gazebo gui="" guiplugin.hh=""> is missed. So I looked into the include directory and found there was no such a header file. I searched on the Internet and hardly got anything, so I am stuck here and need some help. I installed gazebo-4.0 from the source code a few days ago and still was not familar with it. Did I missed something when I installed it? Or something else? Thanks.
Which source file? And, can you post the console output?
nkoenig gravatar imagenkoenig ( 2014-10-29 18:17:19 -0500 )edit
Thanks. https://bitbucket.org/osrf/gazebo/src/default/examples/plugins/guioverlayplugin_spawn/ Here's the link of the source code. After the cmake step, I met the following errors when make it--fatal error: gazebo/gui/GuiPlugin.hh: No such file or directory.-- In the path /usr/local/include/gazebo4.0/gazebo, there exist other header files like <gui.hh> and <Plugin.hh> but no <GuiPlugin.hh>. So I have no idea what has gone wrong.
BenWashburn gravatar imageBenWashburn ( 2014-10-29 22:01:52 -0500 )edit
Here's the total console output: In file included from /home/ben/gazeboguispawn/build/mocGUIExampleSpawnWidget.cxx:9:0: /home/ben/gazeboguispawn/build/../GUIExampleSpawnWidget.hh:21:35: fatal error: gazebo/gui/GuiPlugin.hh: No such file and directory #include <gazebo/gui/GuiPlugin.hh> compilation terminated make[2]: * [CMakeFiles/guiexamplespawnwidget.dir/mocGUIExampleSpawnWidget.cxx.o] error 1 make[1]: * [CMakeFiles/guiexamplespawnwidget.dir/all] error 2 make: * [all] error 2
BenWashburn gravatar imageBenWashburn ( 2014-10-29 23:19:05 -0500 )edit
answered 2014-10-30 12:24:36 -0500
scpeters gravatar image
The GuiPlugin.hh header file is not present in gazebo4 and earlier. You must use the default branch (or gazebo_5.* or later branches once they are created).
Thanks a lot. That's quite helpful.
BenWashburn gravatar imageBenWashburn ( 2014-10-30 23:14:22 -0500 )edit
So how can I use "Overlay Gui" in earlier version of gazebo (e.g. gazebo2)
mohammadkassemzein gravatar imagemohammadkassemzein ( 2018-11-09 06:52:24 -0500 )edit
You can't, you must upgrade Gazebo.
chapulina gravatar imagechapulina ( 2018-11-09 10:14:04 -0500 )edit
Asked: 2014-10-28 21:11:21 -0500
Seen: 233 times
Last updated: Oct 30 '14
