tiled floor textures
asked 2014-11-07 08:01:53 -0600
Andrea gravatar image
updated 2015-06-12 03:58:45 -0600
Hello everybody, I am trying to put some textures on the ground plane of my world file (I need features for the optical flow). I have a picture of the floor of the arena and I would like to use it as a texture. However, the picture itself is much smaller than the arena and setting the <size> attribute in the sdf file will stretch it, lowering the overall resolution.
What I would like to do is tiling the texture over all the floor. How can I do it? Here my material script
material labrob/cobblestone {
receive_shadows on
technique   {
       pass
        ambient 0.000000 0.000000 0.000000 1.000000
            emissive 0.000000 0.0000000 0.000000 1.000000
            lighting on
            texture_unit        {
Thank you very much
Andrea
answered 2015-06-13 14:07:46 -0600
chapulina gravatar image
You could use scale inside your texture_unit to repeat the texture several times in the same area. The asphalt_plane is a good example, there the texture is repeated 10 times in each direction.
The scale should be [1 1] by default, a scale of [0.5 0.5] would repeat the texture twice in each direction and so on.
That solved my problem. Thank you very much!
Andrea gravatar imageAndrea ( 2015-06-23 02:55:38 -0600 )edit
Asked: 2014-11-07 08:01:53 -0600
Seen: 2,554 times
Last updated: Jun 13 '15
