How to add model of object from non default localisation?
asked 2014-11-17 15:24:20 -0500
green96 gravatar image
updated 2014-11-17 16:36:11 -0500
could you tell me:
  • is there any option to add model of object from non default localisation? like: add different path to this GUI? http://snag.gy/Du37O.jpg
  • I am using ROS and Gazebo and I am a little bit confused, what is the extension of models (objects which can be added to the world)?
    .sdf, .world, .model, .dae?
answered 2014-11-17 15:32:02 -0500
nkoenig gravatar image
The paths displayed in the Insert Model Tab correlate to the GAZEBO_MODEL_PATH environment variable.
SDF & URDF serve roughly the same purpose. Both are formats that describe robots (models). SDF has additional capabilities, such as supporting lights, terrain, sensors, etc. The extensions '.model' and '.world' are hold-overs from early versions of Gazebo. A '.model' file is an SDF file that contains one model, while a '.world' file is an SDF file that contains the description of an entire environment.
DAE files are used to describe 3D meshes and their textures.
Thank you for your answer. I add path to the .bashrc file, and this path appear in insert tag, but I can't choose anything. This folder which is linked to this variable consist *.model files. Do you have any idea what is wrong? http://snag.gy/HNwe5.jpg please check it: http://pastebin.com/mebhNW1R I am not sure but is this normal that when I call echo it gives ' : ' sign before path?
green96 gravatar imagegreen96 ( 2014-11-17 16:15:01 -0500 )edit
Is it a bug? when I call echo I get " : " before or after path... http://pastebin.com/HtVNj7M7
green96 gravatar imagegreen96 ( 2014-11-17 17:44:33 -0500 )edit
Gazebo expects models to be contained in directories. One directory per model. Each directory should have a `model.config` file along with your SDF file(s), textures, meshes, etc. Take a look in `~/.gazebo/models` for examples.
nkoenig gravatar imagenkoenig ( 2014-11-18 10:40:25 -0500 )edit
I know, I had checked it before but I have only *.models and *.dae files. I would like to add tag / mark to gazebo. I know that it was possible and it was working when ROS fuerte was released. Like here: https://www.youtube.com/watch?v=wG1OHN7ik3w Some time ago, there was different standard to add models to world?
green96 gravatar imagegreen96 ( 2014-11-18 11:15:04 -0500 )edit
The model.config file is used to tell Gazebo about a model. Make sure that you have a model.config in your model directory. Also make sure that the model.config refers to the correct SDF file, which should exist in the same directory as the model.config file.
nkoenig gravatar imagenkoenig ( 2014-11-18 11:38:19 -0500 )edit
Unfortunately I don't have any sdf file and model.config file. Should I create them? I spend some time and I found in google that few years ago people ad files like here: http://answers.ros.org/question/43809/unable-to-include-model-files-for-objects-in-world-file-for-simulation-in-ubuntu-1204-fuerte/ or like here: http://answers.ros.org/question/42529/how-to-import-collada-dae-files-into-gazebo-rosfuerte/ so what is the best solution? creation .sdf files or using URDF?
green96 gravatar imagegreen96 ( 2014-11-18 12:17:31 -0500 )edit
I am asking because posts which I linked are a little bit old. What should I do?
green96 gravatar imagegreen96 ( 2014-11-18 12:21:40 -0500 )edit
Can you take a look at this tutorial? It might help you.
nkoenig gravatar imagenkoenig ( 2014-11-18 12:38:55 -0500 )edit
Thank you for your support!
green96 gravatar imagegreen96 ( 2014-11-20 12:50:12 -0500 )edit
Sure thing.
nkoenig gravatar imagenkoenig ( 2014-11-20 17:42:16 -0500 )edit
Asked: 2014-11-17 15:24:20 -0500
Seen: 2,385 times
Last updated: Nov 17 '14
