How to simulate viscous forces on the entire model or links ??
asked 2014-12-05 05:04:42 -0500
I am working on the simulation of an underwater vehicle. I have found ways to add viscous damping forces on the joints. But in my case I need to create a world that applies viscous drag on the entire vehicle.Please help!!
answered 2014-12-05 16:46:54 -0500
You will have to write a plugin to handle this. Here is some example code that applies drag to links.
The above link to the mud plugin could be used as a crude simulation of water. Just make a large box that has the mud plugin attached to it, turn off or lower gravity, and put your vehicle inside the box. Make sure your vehicle uses collide_without_contact.
Thanks a lot. That was quite useful. But since viscous drag depends on dot product of area and velocity, does just setting one damping value take care of the different drag forces that arise when the vehicle moves in x,y,z directions?? In other words is the damping value we set, the viscosity of the medium ??
tejdeep gravatar imagetejdeep ( 2014-12-06 04:12:11 -0500 )edit
Sadly, that example plugin uses the same parameter for each direction. Can you create an issue for this feature request? I think it would be a great addition to gazebo.
scpeters gravatar imagescpeters ( 2014-12-07 23:03:33 -0500 )edit
Asked: 2014-12-05 05:04:42 -0500
Seen: 706 times
Last updated: Dec 05 '14
