Plugin automatic compiling
Can anyone help me to find how to compile in an automatic way a plugin without the manual way in the terminal ?
thanks in advance
Another idea: if your controller can be parameterized, then you could compile the plugin once and read in a separate parameter file for each test run.
Asked: 2014-12-10 10:12:19 -0500
Seen: 128 times
Last updated: Dec 16 '14
Effect of Stiffness and Mass on Gazebo Simulation stability
Plugin problem launching .launch
What should I do? libvelodyne_plugin. can not find
gazebo bumper plugin wont give me any data ?
Gazebo / URDF human model (with joints, not an actor)
model falls when spawned in gazebo
How to start gazebo using roscore & rosrun gazebo_ros gazebo?
How to simulate a Stewart Platform with Gazebo and ROS?
for more detail, I am trying to use genetic algorithms to evolve morphologies and controllers of many robots at the same time, so I am wondering how to compile a plugin of a new robot at run time simulation programmatically.
