InsertModelSDF potential race condition
asked 2014-12-16 00:47:23 -0600
mkoval gravatar image
I am trying to programmatically add objects to an environment with InsertModelSDF. There seems to be a race condition that causes this to sporadically fail if InsertModelSDF is called too quickly after init_world. This test script reliably fails on the first iteration and, additionally, sometimes fails on the second iteration of the loop:
Additionally, I noticed a few other quirks that are potentially relevant:
  1. GetModel only returns the new model after runWorld has run for at least one timestep.
  2. There is no reliable way of telling if InsertModelSDF failed.
Am I doing something wrong in my test script (e.g. neglecting acquire a lock)? Also, is there any way to force this data to refresh without running a simulation timestep?
In your test script you don't declare `model_path`. Can you fix it?
NickDP gravatar imageNickDP ( 2014-12-16 15:31:33 -0600 )edit
I accidentally removed that line when cleaning up the code. It's fixed now (same URL).
mkoval gravatar imagemkoval ( 2014-12-17 01:26:51 -0600 )edit
answered 2014-12-16 14:05:57 -0600
Regarding your additional questions, my question and nkoenig's answer here is relevant.
This is likely the source of the issue. However, I am not sure why. I am manually triggering simulation timesteps with the gazebo::runWorld function. Shouldn't this force processing of the queue?
mkoval gravatar imagemkoval ( 2014-12-16 14:54:59 -0600 )edit
answered 2014-12-17 10:31:59 -0600
nkoenig gravatar image
This happens because we don't process messages every iteration of simulation. Our strategy is to let messages that don't need immediate processing to linger a bit. The effect is a small delay in things like inserting new models, with more time given to the physics engine.
Thanks! What is the recommended way of waiting for the model to be inserted? @NickDP's post uses a spinlock to wait until GetModelCount() increases. I am attempting to use Gazebo programmatically (in-process), so it is undesirable to trigger several physics updates every time I add a model. Ideally, I'd like to run the message processing manually (without also triggering a simulation step).
mkoval gravatar imagemkoval ( 2014-12-17 11:07:37 -0600 )edit
You should be able to listen to the ~/model/info topic. Or you can connect to the addEntity event.
nkoenig gravatar imagenkoenig ( 2014-12-17 11:14:04 -0600 )edit
Thanks. The `AddEntry` event looks like what I want. Is there any way to process the message queue without also triggering a simulation step?
mkoval gravatar imagemkoval ( 2014-12-17 11:35:33 -0600 )edit
Asked: 2014-12-16 00:47:23 -0600
Seen: 247 times
Last updated: Dec 17 '14
