Why setting the angular velocity changes the force of contact joint
asked 2015-01-01 13:56:29 -0500
shpower gravatar image
Hey all,
I created a cylinder (Wheel) on a ground plane. when the wheel was at rest the contact force was the weight of the wheel (~25.0 N). after I applied a constant angular velocity(linear is 0) by SetAngularVel(), the contact force on the wheel changed to be sinusoidal (from -25.0 to 25.0). Can somebody explain that?
Thanks in advance
How are you reading the force? Since force is a vector, your reference frame is probably spinning with respect to the force.
chapulina gravatar imagechapulina ( 2015-01-05 10:21:38 -0500 )edit
I read it from physics gztopic. What do you mean?
shpower gravatar imageshpower ( 2015-03-04 16:01:47 -0500 )edit
