Changing pixel size of camera
asked 2015-03-19 06:10:38 -0500
Paulo gravatar image
how do you change the pixel size of a URDF camera?
I follow the tutorial in Gazebo but it doesn't say how to do this.
Thx so much friends.
2
answered 2015-03-19 11:43:22 -0500
nkoenig gravatar image
You'll need to use SDF.
If you have to use URDF, then you'll need to add a gazebo extension to URDF that specifies an <image> <width> and <height>.
I did that and I got a bigger image. But does that change the size of the pixels? I don't want to change the size of the image I want to change the size of the pixels. I want better resolution by having smaller pixels
Paulo gravatar imagePaulo ( 2015-03-19 12:42:48 -0500 )edit
Camera resolution is the number of pixels in the image, which is specified by <width> and <height>. The "size" of pixels is a concept for print and display on a monitor. For example, a digital camera has a resolution but you can't set the "size" of the output pixels.
nkoenig gravatar imagenkoenig ( 2015-03-19 12:53:40 -0500 )edit
It worked thx. I was confused sorry.
Paulo gravatar imagePaulo ( 2015-03-19 13:11:58 -0500 )edit
Asked: 2015-03-19 06:10:38 -0500
Seen: 652 times
Last updated: Mar 19 '15
