accuracy of contact sensor ?
asked 2015-05-08 18:36:10 -0600
djou07 gravatar image
updated 2015-05-13 12:43:24 -0600
Hi every body :)
why when I put a link of a model on the ground, its contact sensor indicates that the link don't touch the ground ?
like this graph shows, 1 if link touches the ground, -1 else
the link doesn't move and stay in place. Normally the data of the sensor should be always 1 !
Is this a bug ? If not this means that the if link is not heavy it doesn't touch 100% the ground.I tried to make the link heavier (100 Kg), same problem.
image description
EDIT
Here is the source code :
controller.cc
controller.hh
world.world
CMakeLists.h (change the extension to .txt)
cmd.h (if you want to plot with gnuplot)
the model is in this video. the box is fixed to the ground
answered 2015-05-14 02:17:53 -0600
I resolved the problem by changing the update rate.
First I didn't precise it. By default the frequency is 1000 times per second. So I modified it to 100 and then to 30. And it worked. Still don't understand why it loses accuracy with big frequency...
So, I want to know what is the recommended frequency ?
thanks in advance
answered 2015-05-13 10:05:18 -0600
niall gravatar image
Some code would help on how you implemented your contact sensor? I had something similar to this and it was because I was reading multiple contacts at the same time. Or maybe your link (box?) is flipping from one corner to another?
thank you very much for your answer, I updated the question. maybe it will flip if the force applied is not enough. but I set 3 N.
djou07 gravatar imagedjou07 ( 2015-05-13 12:48:58 -0600 )edit
Asked: 2015-05-08 18:36:10 -0600
Seen: 592 times
Last updated: May 14 '15
