Bug: Gazebo segmentation fault - PR2 spawn - Ubuntu Precise Lucid
ROS Fuerte, Gazebo 1.6.16
Hi all,
I've been trying to get Gazebo running on another laptop.
I tried Ubuntu 12.04.1 Precise 64bit,
Ubuntu 10.04.4 Lucid 32bit and 64bit,
various versions of NVidia proprietory drivers from 195.xx and 304.xx series.
In all cases, Gazebo crashes with segmentation fault when getting near the end of completely spawning the PR2.
In this case in seems to be from libc.so.6.
(Other software configurations have segfaulted in a Boost or OpenGL library.)
This bug report focuses on Ubuntu 10.04.4 64bit:
$ glxinfo
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: Quadro FX 3500/PCI/SSE2
OpenGL version string: 2.1.2 NVIDIA 195.36.24
OpenGL shading language version string: 1.20 NVIDIA via Cg compiler
Executing:
roslaunch gazebo_worlds empty_world.launch
with Gazebo set to debug. That loads fine, until I spawn the PR2 using:
roslaunch pr2_gazebo pr2.launch
which causes a segfault in the first console.
See backtrace below. Problem in libc.so.6 after calling Ogre::GLFrameBufferObject::initialise ?
While leaving the crashed programs running
ps -ef | grep gz
produces
/bin/bash /opt/ros/fuerte/stacks/simulator_gazebo/gazebo_worlds/scripts/gdbrun /opt/ros/fuerte/stacks/simulator_gazebo/gazebo/gazebo/bin/gzserver /opt/ros/fuerte/stacks/simulator_gazebo/gazebo_worlds/worlds/empty.world __name:=gazebo __log:=/home/dbworth/.ros/log/02fc2ece-601f-11e2-8f89-00c0ca21e421/gazebo-2.log -s /opt/ros/fuerte/stacks/simulator_gazebo/gazebo/lib/libgazebo_ros_paths_plugin.so -s /opt/ros/fuerte/stacks/simulator_gazebo/gazebo/lib/libgazebo_ros_api_plugin.so
gdb -x /tmp/gdbrun.20686.7.tmp /opt/ros/fuerte/stacks/simulator_gazebo/gazebo/gazebo/bin/gzserver
/opt/ros/fuerte/stacks/simulator_gazebo/gazebo/gazebo/bin/gzclient -g /opt/ros/fuerte/stacks/simulator_gazebo/gazebo/lib/libgazebo_ros_paths_plugin.so
Also see below for output of:
thread apply all bt
I was going to try to build the normal and HG versions from source, but
hg clone https://bitbucket.org/osrf/gazebo gazebo
gives
requesting all changes
abort: HTTP Error 400: Bad Request
Any help would be most appreciated.
Cheers,
David.
Backtrace:
terminate called after throwing an instance of 'Ogre::InvalidParametersException'
what(): OGRE EXCEPTION(2:InvalidParametersException): All framebuffer formats with this texture internal format unsupported in GLFrameBufferObject::initialise at /tmp/buildd/ros-fuerte-visualization-common-1.8.4/debian/ros-fuerte-visualization-common/opt/ros/fuerte/stacks/visualization_common/ogre/build/ogre_src_v1-7-3/RenderSystems/GL/src/OgreGLFrameBufferObject.cpp (line 276)
Program received signal SIGABRT, Aborted.
0x00007ffff11e3a75 in raise () from /lib/libc.so.6
(gdb) bt
#0 0x00007ffff11e3a75 in raise () from /lib/libc.so.6
#1 0x00007ffff11e75c0 in abort () from /lib/libc.so.6
#2 0x00007ffff1a998c5 in __gnu_cxx::__verbose_terminate_handler() () from /usr/lib/libstdc++.so.6
#3 0x00007ffff1a97cf6 in ?? () from /usr/lib/libstdc++.so.6
#4 0x00007ffff1a97d23 in std::terminate() () from /usr/lib/libstdc++.so.6
#5 0x00007ffff1a97e1e in __cxa_throw () from /usr ...
Related? https://bitbucket.org/osrf/gazebo/issue/132/startup-error-on-some-gpus
and? http://answers.gazebosim.org/question/658/gazebo-pr2-getting-stuck-at-launch/
