GetAngle don't give an exacte value
asked 2015-05-18 11:37:28 -0500
djou07 gravatar image
updated 2015-05-21 18:14:54 -0500
Hi every body
When I set the joint of an angle to a specific value and then I read it I don't have the same value. And each time a different value.
Example:
this->jointController->SetJointPosition(joint, 0.0);
I get the joint by:
this->joint->GetAngle(2).Radian();
and the value I get are either:
-0.002423015843935 or -0.000104254624437 or 0.000201667337713....
And if I set the angle to 0.5 I get:
0.5000000001 or 0.49999999
This really affects the results of my work. What do you think ?
thanks in advance!
EDIT
The source code
#include <boost/bind.hpp>
#include <gazebo/gazebo.hh>
#include <stdio.h>
using namespace std;
namespace gazebo
    class SetJoints : public ModelPlugin
        this->model = _parent;
        this->controller = new physics::JointController(model);
        this->updateConnection = event::Events::ConnectWorldUpdateBegin(boost::bind(&SetJoints::OnUpdate, this, _1));
    public: void OnUpdate(const common::UpdateInfo & )
        //If I set the index it will not set the angle to specific angle
        //controller->SetJointPosition(this->model->GetJoint("joint"), 2, 1);
        controller->SetJointPosition(this->model->GetJoint("joint"), 1.5);
        cout.precision(15);
        cout << fixed << this->model->GetJoint("joint")->GetAngle(1).Radian() << endl;
    private: physics::JointController * controller;
GZ_REGISTER_MODEL_PLUGIN(SetJoints)
the SDF file
<?xml version='1.0'?>
<sdf version='1.4'>
<world name="default">
  <uri>model://sun</uri>
<model name="monModele">
  <link name='bras1'>
    <pose>0 0.4 0.025 0 0 0</pose>
    <collision name='collision'>
          <size>.4 .4 .05</size>
    <visual name='visual'>
  <link name='bras2'>
    <pose>0.4 0.4 0.025 0 0 0</pose>
  <joint type="revolute" name="joint">
    <pose>.2 0 0 0 0 0</pose>
    <child>bras1</child>
    <parent>bras2</parent>
    <axis>
      <xyz>0 1 0</xyz>
    </axis>
  <joint type="revolute" name="jointGround">
    <pose>0 0 -0.025   0 0 0</pose>
    <parent>world</parent>
    <child>bras2</child>
    <axis>
      <xyz>0 1 0</xyz>
      <limit>
        <lower>0</lower><upper>0</upper>
      </limit>
    </axis>
  <plugin name="set_joints" filename="build/libset_joints.so"/>
</world>
Is your joint interacting with physics? It might have slightly moved since you set it.
chapulina gravatar imagechapulina ( 2015-05-18 12:56:09 -0500 )edit
yes. I get the angle in the same update loop, so if the joint will move, it will be in next update loop isn't it ?
djou07 gravatar imagedjou07 ( 2015-05-18 13:40:42 -0500 )edit
answered 2015-05-18 17:59:44 -0500
nkoenig gravatar image
Looks like you are setting the joint angle using index=0, but reading the joint angle using index=2. See here
What type of joint are you using?
I am using a revolute joint. When I specify the index=2 in SetJointPosition It does not work. I mean that it don't set the angle to the specific value. But even If the joint rotate in x axis, it gives same problem.
djou07 gravatar imagedjou07 ( 2015-05-19 05:17:51 -0500 )edit
I added the source code. thanks in advance :)
djou07 gravatar imagedjou07 ( 2015-05-19 07:02:09 -0500 )edit
is there any way to get joint values directly from the ODE engine ?
djou07 gravatar imagedjou07 ( 2015-05-21 12:00:31 -0500 )edit
Revolute joints only have 1 axis, with index 0. Revolute2 joints, for example, have 2 axes, with indices 0 and 1. There are no joints with more than 2 axes, so an index 2 shouldn't work. Therefore, you probably want to use GetAngle(0).
chapulina gravatar imagechapulina ( 2015-05-21 12:18:22 -0500 )edit
thanks for the explanation. I thought that the index is the axis in witch the joint rotate. o for x, 1 for y and 2 for z
djou07 gravatar imagedjou07 ( 2015-05-21 18:20:16 -0500 )edit
Even when I use GetAngle(0) I get different values :/
djou07 gravatar imagedjou07 ( 2015-05-23 05:11:09 -0500 )edit
Asked: 2015-05-18 11:37:28 -0500
Seen: 3,063 times
Last updated: May 21 '15
