Reuse .sdf using different mesh files
asked 2015-06-20 18:16:25 -0500
IsaacS gravatar image
Say I have an sdf file like below:
<?xml version="1.0" ?>
<sdf version="1.4">
    <model name="bookertshelf">
      <link name="body">
            <mesh><uri>model://bookertshelf/dummy.dae</uri></mesh>
I have bookertshelf-%X%.dae files for all of which I like to use the same SDF config above. Is there a way to reuse this SDF file without doubling the file?
In my world file I tried the following that doesn't seem to be doing what I want (without error on console).
  <name>bookertshelf1</name>
  <pose>0 -6.0 0 1.5708 0 -1.5708</pose>
  <uri>model://bookshelf</uri>
  <mesh><uri>model://bookertshelf/bookertshelf1.dae</uri></mesh>
I'm on Ubuntu Trusty, Gazebo 2.2.5. Upper version of Gazebo can't be an option since I'm using ROS Indigo where 2.2 seems like a must.
answered 2015-06-21 21:05:12 -0500
chapulina gravatar image
updated 2015-06-21 21:06:46 -0500
You could use erb to automatically generate your SDF as in this example.
You would need a file, named for example meshes.world.erb, similar to this:
  mesh_list = ["mesh0.dae", "mesh1.dae", "mesh2.dae"]
<sdf version="1.4">
  <world name="default">
    <% # Loop through list
      i = 0
      mesh_list.each do |m|
        name = 'model_' + i.to_s
        i = i + 1
      <%= "<model name='#{name}'>" %>
        <link name="body">
              <mesh><uri><%= "model://bookertshelf/" + m %></uri></mesh>
    <% end %>
  </world>
Then use erb to generate the world file (which I called meshes.world), from the command line:
erb meshes.world.erb > meshes.world
Then open the world on gazebo:
gazebo meshes.world
Thanks. Originally I was hoping for a way to "reuse" a single SDF, not replicating SDF files, but after having seen discussions at another places (e.g. this) I now understand using erb is the best available option for SDF.
IsaacS gravatar imageIsaacS ( 2015-07-03 18:02:11 -0500 )edit
Asked: 2015-06-20 18:16:25 -0500
Seen: 305 times
Last updated: Jun 21 '15
