Gazebo easiest way to apply preload force on a model programmatically?
asked 2015-07-01 13:48:43 -0600
Skylion gravatar image
updated 2015-07-01 13:49:06 -0600
I am implementing a feature that exports robot models to Gazebo. One of the the features that you the CAD software I am using has is the ability to designate spring joints that will have a force applied to them as soon as the simulation starts. I have found several ways to apply forces including via ROS, URDF, and plugins. However, ROS would require running a separate program or script and using plugins would require me to effectively have the program generate and compile cc++ code, which would not be an easy feat. As such, I am wondering what would be the best way to apply a force on the joint at the start of the simulation?
Is there a way I can parametrize plugins from gazebo? For instance, compile a generic plugin file and then have commandline arguments to specify which joints receive how much force? Or would I have to go and using scripting and other features to both write and compile plugins for any model that uses this feature?
answered 2015-07-30 11:34:38 -0600
Using Spring Reference and Stiffness solved my issue in this regard. Unfortunately, I have not found any features in Gazebo to run commands at specified times.
See this question if that is what you are looking for
@Skylion - Did the applied forces work to move links? Were you able to get the joint/ spring in "compression"? Please let me know if you have any thoughts in regards to: http://answers.gazebosim.org/question/14826/how-to-reduce-joint-distance-after-simulation-start/ and http://answers.gazebosim.org/question/14837/how-to-move-a-prismatic-or-other-joint-to-negative-limits/. Applying forces (possibly without a joint even) may be an option?
imlearning gravatar imageimlearning ( 2016-11-17 09:55:39 -0600 )edit
Asked: 2015-07-01 13:48:43 -0600
Seen: 11,372 times
Last updated: Jul 30 '15
