Cannot control joint from pygazebo
asked 2015-07-02 10:39:24 -0600
Skylion gravatar image
updated 2015-07-02 10:44:02 -0600
So I am trying to control a joint from the following world file: exported.world
While I can move the joint with the following command via terminal
gz joint -m 'default_body' -j hingejoint0 -f 10000
I cannot move the same joint with the following python script using PyGazebo:
import trollius
from trollius import From
import pygazebo
import pygazebo.msg.joint_cmd_pb2
@trollius.coroutine
def publish_loop():
    manager = yield From(pygazebo.connect())
    publisher = yield From(
        manager.advertise('/gazebo/default/model/joint_cmd',
                          'gazebo.msgs.JointCmd'))
    message = pygazebo.msg.joint_cmd_pb2.JointCmd()
    message.name = 'default_bot::hingejoint0'
    #message.axis = 0
    message.force = 10000
    while True:
        yield From(publisher.publish(message))
        yield From(trollius.sleep(1.0))
loop = trollius.get_event_loop()
loop.run_until_complete(publish_loop())
What am I doing wrong? Am I sending the command to the wrong endpoint? is my message improperly formatted?
I am using Gazebo 4.1.0 on Ubuntu with the Simbody physics engine.
answered 2015-07-02 10:50:00 -0600
nkoenig gravatar image
I believe you are advertising on the wrong topic. Try:
manager.advertise('/gazebo/world/default_body/joint_cmd', 'gazebo.msgs.JointCmd'))
The topic name is /gazebo/WORLDNAME/MODELNAME/joincmd. In your case WORLD_NAME="world", and MODEL_NAME="defaultbody", based on your SDF file.
Thank you, I just submitted a pull request to the repo to update their example code for those unfamiliar with how topics are generated.
Skylion gravatar imageSkylion ( 2015-07-02 12:07:43 -0600 )edit
Asked: 2015-07-02 10:39:24 -0600
Seen: 6,360 times
Last updated: Jul 02 '15
