FILENAME WHEN USING DiffDrivePlugin6w hector_gazebo plugin
asked 2015-08-20 04:59:14 -0600
ROS_GAZEBO_USER gravatar image
Can someone tell me which filename do I have to put here: (if I write libgazeborosdiff_drive.so it doesn't work...)
image description
Thank you!!
answered 2015-08-20 10:28:12 -0600
The filename is libdiffdriveplugin6w.so (you can see it when you do the catkin_make)
answered 2015-08-20 09:13:44 -0600
nkoenig gravatar image
The filename must be a valid Gazebo plugin. The plugin must also be in your LD_LIBRARY_PATH and/or in the GAZEBO_PLUGIN_PATH.
Asked: 2015-08-20 04:59:14 -0600
Seen: 152 times
Last updated: Aug 20 '15
