Plugin problem launching .launch
asked 2015-09-11 06:18:08 -0600
Alvaro Salcedo gravatar image
updated 2015-09-14 06:19:16 -0600
Hi Gazebo users:
I have just created a pkg following this page link text It just creates a plugin and a world with the plugin. My problem is that when I launch the .launch terminal says:
gzserver: symbol lookup error: /home/alcor/catkin_ws/devel/lib/libgazebo_light_sensor_plugin.so: undefined symbol: _ZN6gazebo20GazeboRosCameraUtilsC2Ev
[gazebo-1] process has died [pid 20107, exit code 127, cmd /home/alcor/catkin_ws/src/gazebo_ros_pkgs/gazebo_ros/scripts/gzserver --verbose -e ode /home/alcor/catkin_ws/src/gazebo_light_sensor_plugin/worlds/light.world __name:=gazebo __log:=/root/.ros/log/2a55e3fe-5872-11e5-af06-fcaa14787194/gazebo-1.log].
log file: /root/.ros/log/2a55e3fe-5872-11e5-af06-fcaa14787194/gazebo-1*.log
And Gazebo opens a black screen.
What am I doing wrong? How can I solve it?
Thanks a lot
EDIT:
LAUNCH FILE:
<launch>
 <!-- We resume the logic in empty_world.launch, changing only the name of the world to be launched -->
 <arg name="verbose" value="true"/>
 <arg name="world_name" value="$(find gazebo_light_sensor_plugin)/worlds/light.world"/>
 <!-- more default parameters can be changed here -->
 </launch>
.CPP FILE
#include <ros/ros.h>
#include "/home/alcor/catkin_ws/src/gazebo_light_sensor_plugin/include/gazebo_light_sensor_plugin/light_sensor_plugin.h"
#include "gazebo_plugins/gazebo_ros_camera.h"
#include <string>
#include <gazebo/sensors/Sensor.hh>
#include <gazebo/sensors/CameraSensor.hh>
#include <gazebo/sensors/SensorTypes.hh>
#include <sensor_msgs/Illuminance.h>
namespace gazebo
 GZ_REGISTER_SENSOR_PLUGIN(GazeboRosLight)
 // Constructor
 GazeboRosLight::GazeboRosLight():
 _nh("light_sensor_plugin"),
 _fov(6),
 _range(10)
 _sensorPublisher = _nh.advertise<sensor_msgs::Illuminance>("lightSensor", 1);
 // Destructor
 GazeboRosLight::~GazeboRosLight()
 ROS_DEBUG_STREAM_NAMED("camera","Unloaded");
 void GazeboRosLight::Load(sensors::SensorPtr _parent, sdf::ElementPtr _sdf)
 // Make sure the ROS node for Gazebo has already been initialized
 if (!ros::isInitialized())
 ROS_FATAL_STREAM("A ROS node for Gazebo has not been initialized, unable to load plugin. "
 << "Load the Gazebo system plugin 'libgazebo_ros_api_plugin.so' in the gazebo_ros package)");
 return;
 CameraPlugin::Load(_parent, _sdf);
 // copying from CameraPlugin into GazeboRosCameraUtils
 this->parentSensor_ = this->parentSensor;
 this->width_ = this->width;
 this->height_ = this->height;
 this->depth_ = this->depth;
 this->format_ = this->format;
 this->camera_ = this->camera;
 GazeboRosCameraUtils::Load(_parent, _sdf);
 // Update the controller
 void GazeboRosLight::OnNewFrame(const unsigned char *_image,
 unsigned int _width, unsigned int _height, unsigned int _depth,
 const std::string &_format)
 static int seq=0;
 this->sensor_update_time_ = this->parentSensor_->GetLastUpdateTime();
 if (!this->parentSensor->IsActive())
 if ((*this->image_connect_count_) > 0)
 // do this first so there's chance for sensor to run once after activated
 this->parentSensor->SetActive(true);
 else
 common::Time cur_time = this->world_->GetSimTime();
 if (cur_time - this->last_update_time_ >= this->update_period_)
 this->PutCameraData(_image);
 this->PublishCameraInfo();
 this->last_update_time_ = cur_time;
 sensor_msgs::Illuminance msg;
 msg.header.stamp = ros::Time::now();
 msg.header.frame_id = "";
 msg.header.seq = seq;
 int startingPix = _width * ( (int)(_height/2) - (int)( _fov/2)) - (int)(_fov/2);
 double illum = 0;
 for (int i=0; i<_fov ; ++i)
 int index = startingPix + i*_width;
 for (int j=0; j<_fov ; ++j)
 illum += _image[index+j];
 msg.illuminance = illum/(_fov*_fov);
 msg.variance = 0.0;
 _sensorPublisher.publish(msg);
 seq++;
.H FILE
#ifndef GAZEBO_ROS_LIGHT_SENSOR_HH
#define GAZEBO_ROS_LIGHT_SENSOR_HH
#include <string>
// library for processing camera data for gazebo / ros conversions
#include <gazebo/plugins ...
(more)
Can you post a copy of your launch file?
scpeters gravatar imagescpeters ( 2015-09-14 00:50:07 -0600 )edit
Of course @scpeters . I have just edited the post
Alvaro Salcedo gravatar imageAlvaro Salcedo ( 2015-09-14 05:01:37 -0600 )edit
And also your plugin source code? I had this error not that long ago and it was something silly like having an old function declared in the header but not defined.
niall gravatar imageniall ( 2015-09-14 06:15:33 -0600 )edit
Yes! here you are! .cpp and .h @niall Thanks!
Alvaro Salcedo gravatar imageAlvaro Salcedo ( 2015-09-14 06:20:26 -0600 )edit
answered 2015-09-17 05:32:02 -0600
Can anybody help me? Thank you so much. I can not fix it.
I'm sorry, I can't find what you're doing wrong. Not a C++ guru myself. What helped me was follow this part of the error: "undefined symbol: _ZN6gazebo20GazeboRosCameraUtilsC2Ev". The gazebo part likely means the problem originates in that namespace, in the GazeboRosCameraUtils part with a function starting with "Ev". That's how I found my error.
niall gravatar imageniall ( 2015-09-17 16:19:57 -0600 )edit
I am checking the namespace Gazebo in gazeboroscamera and there is not any function starting with "Ev" @niall . I am desperate...
Alvaro Salcedo gravatar imageAlvaro Salcedo ( 2015-09-18 06:48:17 -0600 )edit
Asked: 2015-09-11 06:18:08 -0600
Seen: 1,263 times
Last updated: Sep 17 '15
