Basic question regarding plugin
asked 2013-01-20 03:16:33 -0600
ChengXiang gravatar image
Hi guys. I have basic questions regarding plugins and I am using Gazebo with ROS. Firstly, in the plugin examples given in the tutorial, there is no main function, only class declaration. So how are the functions within the class in the plugin implemented? Is it that all the functions in “public” will be executed?
Secondly, can I know what this piece of code does?
      // simulation iteration.
      this->updateConnection = event::Events::ConnectWorldUpdateStart(
          boost::bind(&ModelPush::OnUpdate, this));
From what I gather, this means that the ModelPush is binded as a function pointer and it will be call every time the world update by receiving a "world update" signal. Am I right?
If so, why is it that in the "Hello world" example (the first tutorial), the print function will executed?
Thanks
2
answered 2013-01-20 13:07:32 -0600
r0nald gravatar image
updated 2013-01-20 13:08:22 -0600
Plugins do not have a main() function, they are objects that are created by the main gazebo process. The print function in the example gets called, because the constructor HelloWorld::HelloWorld() is called when the object is created (really elementary C++ knowledge).
Almost. The method ModelPush::OnUpdate() of your ModelPush object (this)is called on world update.
I see. Thanks for clarifying!
ChengXiang gravatar imageChengXiang ( 2013-01-21 06:38:03 -0600 )edit
Asked: 2013-01-20 03:16:33 -0600
Seen: 343 times
Last updated: Jan 20 '13
