2
DRCSIM: new API and update rate
asked 2013-01-20 16:27:05 -0500
dcconner gravatar image
updated 2013-01-20 16:28:16 -0500
Thanks for publishing the preliminary API http://gazebosim.org/wiki/DRC/UserGuide.
With regard to the control inputs (subscriptions).
What is the fastest update rate that can be published and received by Gazebo for drcsim?
What is the control loop update rate in simulation time?
What is the expected physics simulation time step?
One can imagine running physics simulation at 0.001 s time step, but simulating a 200 Hz controller at 0.005 second time step (that is control output only updated every 5th simulation time step).
If the physics is only run at 0.005 s, then there is no point designing a controller that depends on 500 hz update rate.
Can you give us guidance on plans and expectations regarding the above questions? This will constrain the control methods that can be used.
I note that the message description uses continuous notation (1/s, s), and not discrete time controller (1/z, z) notation. If intentional, this would imply that controller must run at same update rate as physics, but given limited setpoint update rate would still function as discrete time.
dcconner gravatar imagedcconner ( 2013-01-21 09:53:03 -0500 )edit
answered 2013-01-22 23:03:40 -0500
gerkey gravatar image
The API docs are expanding in advance of the drcsim 2.0 release. Your questions are now addressed there.
Asked: 2013-01-20 16:27:05 -0500
Seen: 299 times
Last updated: Jan 22 '13
