depth camera is publishing wrong rotated pointcloud
asked 2015-10-01 09:29:57 -0500
Jan E. gravatar image
I am new to gazebo and ros. I am trying to simulate a kinect in gazebo and would like to view the data in rviz. But rviz is showing the pointcloud-data related to the Z-axis instead of x-axis. Now I'm not sure if the problem is related to rviz, the gazebo-plugin or the tf. Also wirred is, that he camera image is correct.
Gazebo: 6.1.0 Ros: Indigo Rviz: 1.11.8
image description
image description
mybot.xacro
<link name="chassis">
    <collision>
        <box size=".4 .2 .1"/>
    <visual>
  <joint name="camera_joint" type="fixed">
    <origin xyz=".175 0 .075" rpy="0 0 0"/>
    <parent link="chassis"/>
    <child link="camera_link"/>
  <link name="camera_link">
    <collision>
    <box size="0.05 0.05 0.05"/>
    <visual>
      <material name="orange"/>
      <mass value="1e-5"/>
      <inertia ixx="1e-6" ixy="0" ixz="0" iyy="1e-6" iyz="0" izz="1e-6"/>
mybot.gazebo
<gazebo reference="chassis"></gazebo>
  <gazebo reference="camera_link">
    <sensor type="depth" name="openni_camera_camera">
            <horizontal_fov>1.3962634</horizontal_fov>
                <width>640</width>
                <height>480</height>
                <format>R8G8B8</format>
                <far>100</far>
        <plugin name="camera_controller" filename="libgazebo_ros_openni_kinect.so">
            <alwayson>true</alwayson>
                <updaterate>30.0</updaterate>
                <cameraname>cameraLeft</cameraname>
                <framename>camera_link</framename>
            <imagetopicname>CameraLeft/rgb/image_raw</imagetopicname>
            <depthimagetopicname>CameraLeft/depth/image_raw</depthimagetopicname>
            <pointcloudtopicname>CameraLeft/depth/points</pointcloudtopicname>
            <camerainfotopicname>CameraLeft/rgb/camera_info</camerainfotopicname>
            <depthimagecamerainfotopicname>CameraLeft/depth/camera_info</depthimagecamerainfotopicname>
            <pointcloudcutoff>0.8</pointcloudcutoff>
            <pointcloudcutoffmax>3.5</pointcloudcutoffmax>
answered 2017-03-17 06:54:30 -0500
der.sonic gravatar image
Any answers to this question? I am having the same problem right now. Using libgazebo_ros_camera and libgazebo_ros_openni_kinect controllers. RGB image is displayed properly in RViz, but depth cloud has two problems. One is that gazebo for some reason points depth camera to the left side of the robot/camera, and changing pose tag is not changing anything. At first that was the problem with RGB one, but pose tag helped in that case. Second problem is that in Rviz point cloud is rotated around Y axis I think, so it is in front of the robot, but points down through the ground, and displays the scene from the left side of the robot. Any suggestions? I can provide URDF if needed....
Asked: 2015-10-01 09:29:57 -0500
Seen: 1,222 times
Last updated: Mar 17 '17
