After updating to Gazebo 1.3 under ROS Groovy I get a .launch file error
Another question that might be related to this one.
I am using ROS Groovy and I updated Gazebo to 1.3 (binary version), under Ubuntu 12.04. When launching an empty world with the following .launch file:
<launch>
  <arg name="use_sim_time" default="true"/>
  <!-- set use_sim_time flag -->
  <group if="$(arg use_sim_time)">
    <param name="/use_sim_time" value="true" />
  </group>
  <!-- start empty world -->
  <node name="empty_world_server" pkg="gazebo" type="gazebo" args="$(find hit_hand)/worlds/empty.world" respawn="false" output="screen"/>
  <!-- start gui -->
  <group if="$(arg gui)">
    <node name="gazebo_gui" pkg="gazebo" type="gui" respawn="false" output="screen"/>
  </group>
</launch>
I get the following error:
Press Ctrl-C to interrupt
started roslaunch server http://groovybeetz4:44318/
SUMMARY
PARAMETERS
 * /rosdistro
 * /rosversion
 * /use_sim_time
NODES
    empty_world_server (gazebo/gazebo)
    gazebo_gui (gazebo/gui)
auto-starting new master
process[master]: started with pid [6184]
setting /run_id to 8a994a92-6ace-11e2-b2ca-6cf049e83b7a
process[rosout-1]: started with pid [6197]
process[empty_world_server-2]: started with pid [6211]
process[gazebo_gui-3]: started with pid [6220]
GNU gdb (Ubuntu/Linaro 7.4-2012.04-0ubuntu2.1) 7.4-2012.04
Copyright (C) 2012 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
For bug reporting instructions, please see:
<http://bugs.launchpad.net/gdb-linaro/>...
Reading symbols from /opt/ros/groovy/stacks/simulator_gazebo/gazebo/gazebo/bin/gzserver...(no debugging symbols found)...done.
[tcsetpgrp failed in terminal_inferior: Inappropriate ioctl for device]
Gazebo multi-robot simulator, version 1.3.0
Copyright (C) 2012 Nate Koenig, John Hsu, and contributors.
http://gazebosim.org
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7fffe5e77700 (LWP 6248)]
Msg Waiting for master.[tcsetpgrp failed in terminal_inferior: Inappropriate ioctl for device]
[New Thread 0x7fffdb998700 (LWP 6315)]
[New Thread 0x7fffdb197700 (LWP 6316)]
terminate called after throwing an instance of 'ros::InvalidNameException'
  what():  Character [-] at element [20] is not valid in Graph Resource Name [empty_world_server13-01-30].  Valid characters are a-z, A-Z, 0-9, / and _.
Program received signal SIGABRT, Aborted.
0x00007ffff54b1425 in raise () from /lib/x86_64-linux-gnu/libc.so.6
(gdb)
Did the launch file semantics change, or it is related to the other error?
Thanks, Andrei
