How to understand if my plugin is loaded in gazebo?
Hi again,
I created a ModelPlugin to simulate a motor with spring in a R robot. When I compile the plugin, it works and a file .so is generated. The I add the plugin in my URDF file in this way :
  <gazebo>
    <plugin name="motor_spring_plugin" filename="libmotor_spring_plugin.so">
When I run gazebo with roslaunch there is no error and the robot appears. However I'm not able to understand if my plugin is effectively loaded in my model. How can I test it?
Moreover in this plugin I created a ros_node subscriber in the Load() function:
    if (!ros::isInitialized()) //check if ros is initialized properly
          ROS_FATAL("ROS has not been initialized!");
          return;
  ros::NodeHandle n;
  ros::Subscriber sub=n.subscribe("chatter", 1000, &MotorSpring::Callback, this);
      ...something...
 this->UpdateConnection=event::Events::ConnectWorldUpdateBegin(boost::bind(&MotorSpring::OnUpdate,this,_1));
(the Callback function is defined as public function) Is it true?
When gazebo is running, if I start rostopic list from terminal, the topic chatter doesn't appear.
Why? It is caused by the whole plugin or I made some mistakes in the ros piece of code?
Thank you
