how to solve the question when use poseanimate plugin?
I use a plugin to control a hand model with two fingers from a position(0,0,0) to a high position(0,0,0.5), and the model will shrink up and down, a finger should separate from the hand? the motion is not regular, would you please help me? thank you world file: <plugin name="animate_pose1" filename="libanimate_pose1.so"/> the animate_pose.cc:
  gazebo::common::PoseAnimationPtr anim(
      new gazebo::common::PoseAnimation("box::my_joint5", 10.0, 0));
  gazebo::common::PoseKeyFrame *key = anim->CreateKeyFrame(0.0);
  key = anim->CreateKeyFrame(0);
  key->SetTranslation(math::Vector3(0, 0, 0));
  key = anim->CreateKeyFrame(2.0);
  key->SetTranslation(math::Vector3(0, 0, 0.1));
  key = anim->CreateKeyFrame(4.0);
  key->SetTranslation(math::Vector3(0, 0, 0.2));
  key = anim->CreateKeyFrame(6.0);
  key->SetTranslation(math::Vector3(0, 0, 0.3));
  key = anim->CreateKeyFrame(8.0);
  key->SetTranslation(math::Vector3(0, 0, 0.4));
  key = anim->CreateKeyFrame(10.0);
  key->SetTranslation(math::Vector3(0, 0, 0.5));
  _parent->SetAnimation(anim);
I use a plugin to control a hand model with two fingers from a position(0,0,0) to a high position(0,0,0.5), and the model will shrink up and down, a finger should separate from the hand? the motion is not regular, regular and not smooth, would you please help me? thank you world file: <plugin name="animate_pose1" filename="libanimate_pose1.so"/> the animate_pose.cc:
I use a plugin to control a hand model with two fingers from a position(0,0,0) to a high position(0,0,0.5), and the model will shrink quiver up and down, a finger should separate from the hand? the motion is not regular and not smooth, would you please help me? thank you world file: <plugin name="animate_pose1" filename="libanimate_pose1.so"/> the animate_pose.cc:
how How to solve the question when use poseanimate plugin?animate a hand using a plugin
I use a plugin to control a hand model with two fingers from a position(0,0,0) to a high position(0,0,0.5), and the model will quiver up and down, a finger should separate from the hand? the down. The motion is not regular and not smooth, would you please help me? thank you you
world file: file:
