Gazebo shuts down immediately on start!
Hi :)
after i install gazebo on ubuntu 11.10 with Tarball. after install, i trying to type "gazebo" on terminal:
mohsen@mohsen-ThinkPad-R500:~$ gazebo
Gazebo multi-robot simulator, version 1.4.0
Copyright (C) 2013 Open Source Robotics Foundation.
http://gazebosim.org
Msg Waiting for master.Msg Waiting for master
Msg Publicized address: 192.168.14.139
(gazebo:5099): Gtk-WARNING **: Unable to locate theme engine in module_path: "pixmap",
my gazebo gui show and exit immedietly without any error or warning!
what am i shoud to0 do0? :)
Hi :)
mohsen@mohsen-ThinkPad-R500:~$ env | grep GAZEBO
GAZEBO_RESOURCE_PATH=/home/mohsen/local/share/gazebo-1.4:/home/mohsen/local/share/gazebo_models
GAZEBO_MASTER_URI=http://localhost:11345
GAZEBO_PLUGIN_PATH=/home/mohsen/local/lib/gazebo-1.4/plugins
GAZEBO_MODEL_DATABASE_URI=http://gazebosim.org/models
Hi :)
after i installed with synaptic, it didn,t any error or warning but my gazebo shut down immediately after call!
gmohsen@mohsen-ThinkPad-R500:~$ gazebo
Msg Publicized address: 192.168.1.51
Hi :)
after i installed with "gtk2-engines-pixbuf" by synaptic, it didn,t any error or warning but my gazebo shut down immediately after call!
Hi :)
after i installed "gtk2-engines-pixbuf" by synaptic, it didn,t any error or warning but my gazebo shut down immediately after call!
=============================================================== when i run gzserver: mohsen@mohsen-ThinkPad-R500:~$ gzserver
Gazebo multi-robot simulator, version 1.4.0 Copyright (C) 2013 Open Source Robotics Foundation. Released under the Apache 2 License. http://gazebosim.org
ate gz client:
mohsen@mohsen-ThinkPad-R500:~$ gzclient
Segmentation fault
Gazebo shuts down GUI crashed immediately on start!
Hi :)
ate gz client:
Segmentation fault
Gazebo GUI crashed immediately on start!
Hi :)
=============================================================== when i run gzserver: ===============================================================
mohsen@mohsen-ThinkPad-R500:~$ gzservergdb --args gzserver empty.world
GNU gdb (Ubuntu/Linaro 7.4-2012.04-0ubuntu2.1) 7.4-2012.04
Copyright (C) 2012 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
For bug reporting instructions, please see:
<http://bugs.launchpad.net/gdb-linaro/>...
Reading symbols from /usr/bin/gzserver...Reading symbols from /usr/lib/debug/usr/bin/gzserver-1.5.0...done.
done.
(gdb) run
Starting program: /usr/bin/gzserver empty.world
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7fffe5289700 (LWP 3075)]
ate gz client:
Gazebo multi-robot simulator, version 1.4.0 1.5.0 Copyright (C) 2013 Open Source Robotics Foundation. Released under the Apache 2 License. http://gazebosim.org
License. http://gazebosim.org [New Thread 0x7fffe4a88700 (LWP 3076)] [New Thread 0x7fffdffff700 (LWP 3077)] Msg Waiting for master
master Msg Connected to gazebo master @ http://127.0.0.1:11345
http://127.0.0.1:11345 Msg Publicized address: 192.168.1.51
192.168.1.52 [New Thread 0x7fffd6a68700 (LWP 3078)] [New Thread 0x7fffd6267700 (LWP 3079)] [New Thread 0x7fffd5866700 (LWP 3080)] [New Thread 0x7fffd4c43700 (LWP 3081)] [New Thread 0x7fffc3fff700 (LWP 3082)] [New Thread 0x7fffc37fe700 (LWP 3083)] [New Thread 0x7fffc2ffd700 (LWP 3084)]
mohsen@mohsen-ThinkPad-R500:~$ gdb gzclient
Reading symbols from /usr/bin/gzclient...Reading symbols from /usr/lib/debug/usr/bin/gzclient-1.5.0...done.
done.
(gdb) run
Starting program: /usr/bin/gzclient
[New Thread 0x7fffe431a700 (LWP 3096)]
Gazebo multi-robot simulator, version 1.5.0
[New Thread 0x7fffe3b19700 (LWP 3097)]
Msg Publicized address: 192.168.1.52
[New Thread 0x7fffe310b700 (LWP 3098)]
[New Thread 0x7fffe24e8700 (LWP 3099)]
[New Thread 0x7fffd1548700 (LWP 3100)]
[New Thread 0x7fffd0d47700 (LWP 3101)]
[New Thread 0x7fffbca32700 (LWP 3102)]
[New Thread 0x7fffb7fff700 (LWP 3103)]
[New Thread 0x7fffb6dbf700 (LWP 3104)]
[New Thread 0x7fffb5020700 (LWP 3107)]
[New Thread 0x7fffa4027700 (LWP 3108)]
[New Thread 0x7fffa3826700 (LWP 3109)]
Program received signal SIGSEGV, Segmentation fault
fault. 0x00007fffd2aae307 in ?? () from /usr/lib/fglrx/dri/fglrx_dri.so (gdb)
Hi :)
* i re install ubuntu ,but 12.04 64bit! and try to0 install pre-compile binary gazebo with "synaptic" but still i have this problem! :( *
mohsen@mohsen-ThinkPad-R500:~$ gdb --args gzserver empty.world
done.
(gdb) run
done.
(gdb) run
Program received signal SIGSEGV, Segmentation fault.
(gdb)
Hi :)
done.
(gdb) run
done.
(gdb) run run
2509)]
2510)]
master.
0x7fffe30ea700 (LWP 2514)]
[New Thread 0x7fffe24c7700 (LWP 2519)]
2520)]
2521)]
[New Thread 0x7fffbc819700 (LWP 2525)]
2526)]
[New Thread 0x7fffb6b8e700 (LWP 2527)]
[New Thread 0x7fffb4def700 (LWP 2532)]
2533)]
2534)]
Program received signal SIGSEGV, Segmentation fault. fault. 0x00007fffd2aae307 in ?? () from /usr/lib/fglrx/dri/fglrx_dri.so (gdb) bt
#0  0x00007fffd2aae307 in ?? () from /usr/lib/fglrx/dri/fglrx_dri.so
(gdb)
#1  0x00007fffd2b2410e in ?? () from /usr/lib/fglrx/dri/fglrx_dri.so
#2  0x00007fffd2b24449 in ?? () from /usr/lib/fglrx/dri/fglrx_dri.so
#3  0x00007fffd2037421 in ?? () from /usr/lib/fglrx/dri/fglrx_dri.so
#4  0x00007fffd1f440b8 in ?? () from /usr/lib/fglrx/dri/fglrx_dri.so
#5  0x00007fffd20a35b7 in ?? () from /usr/lib/fglrx/dri/fglrx_dri.so
#6  0x00007fffd23c383d in ?? () from /usr/lib/fglrx/dri/fglrx_dri.so
#7  0x00007fffe0632a20 in Ogre::GLRenderSystem::bindGpuProgram(Ogre::GpuProgram*) () from /usr/lib/x86_64-linux-gnu/OGRE-1.7.4/RenderSystem_GL.so
#8  0x00007ffff1ca05e5 in Ogre::SceneManager::_setPass(Ogre::Pass const*, bool, bool) () from /usr/lib/x86_64-linux-gnu/libOgreMain.so.1.7.4
#9  0x00007ffff1c9b269 in Ogre::SceneManager::SceneMgrQueuedRenderableVisitor::visit(Ogre::RenderablePass*) () from /usr/lib/x86_64-linux-gnu/libOgreMain.so.1.7.4
#10 0x00007ffff1c52d59 in Ogre::QueuedRenderableCollection::acceptVisitorDescending(Ogre::QueuedRenderableVisitor*) const () from /usr/lib/x86_64-linux-gnu/libOgreMain.so.1.7.4
#11 0x00007ffff1c52e01 in Ogre::QueuedRenderableCollection::acceptVisitor(Ogre::QueuedRenderableVisitor*, Ogre::QueuedRenderableCollection::OrganisationMode) const ()
#12 0x00007ffff1c9b7bc in Ogre::SceneManager::renderBasicQueueGroupObjects(Ogre::RenderQueueGroup*, Ogre::QueuedRenderableCollection::OrganisationMode) ()
#13 0x00007ffff1c9a9e7 in Ogre::SceneManager::renderVisibleObjectsDefaultSequence() () from /usr/lib/x86_64-linux-gnu/libOgreMain.so.1.7.4
#14 0x00007ffff1c9f184 in Ogre::SceneManager::_renderScene(Ogre::Camera*, Ogre::Viewport*, bool) () from /usr/lib/x86_64-linux-gnu/libOgreMain.so.1.7.4
#15 0x00007ffff1b066ec in Ogre::Camera::_renderScene(Ogre::Viewport*, bool) () from /usr/lib/x86_64-linux-gnu/libOgreMain.so.1.7.4
#16 0x00007ffff1c6b9f8 in Ogre::RenderTarget::_updateViewport(Ogre::Viewport*, bool) () from /usr/lib/x86_64-linux-gnu/libOgreMain.so.1.7.4
#17 0x00007ffff1c6b91b in Ogre::RenderTarget::_updateAutoUpdatedViewports(bool) () from /usr/lib/x86_64-linux-gnu/libOgreMain.so.1.7.4
#18 0x00007ffff1c6b3be in Ogre::RenderTarget::updateImpl() () from /usr/lib/x86_64-linux-gnu/libOgreMain.so.1.7.4
#19 0x00007ffff1c6b95c in Ogre::RenderTarget::update(bool) () from /usr/lib/x86_64-linux-gnu/libOgreMain.so.1.7.4
#20 0x00007ffff72e0ac8 in gazebo::rendering::Camera::RenderImpl (this=0x32db2e0) at /tmp/buildd/gazebo-1.5.0/gazebo/rendering/Camera.cc:310
#21 0x00007ffff72e0b49 in Render (this=0x32db2e0) at /tmp/buildd/gazebo-1.5.0/gazebo/rendering/Camera.cc:301
#22 gazebo::rendering::Camera::Render (this=0x32db2e0) at /tmp/buildd/gazebo-1.5.0/gazebo/rendering/Camera.cc:295
#23 0x00000000004c5383 in operator() (this=<optimized out>) at /usr/include/boost/function/function_template.hpp:1013
#24 Signal (this=<optimized out>) at /tmp/buildd/gazebo-1.5.0/gazebo/common/Event.hh:126
---Type <return> to continue, or q <return> to quit---
Hi :)
done.
(gdb) run run
2511)]
2512)]
2513)]
2515)]
2516)]
2517)]
2518)]
2522)]
2523)]
2524)]
============================================================================================================================== (in another terminal)
done.
(gdb) run
[New Thread 0x7fffe431a700 (LWP 2509)]
[New Thread 0x7fffe3b19700 (LWP 2510)]
[New Thread 0x7fffe30ea700 (LWP 2514)]
[New Thread 0x7fffd1548700 (LWP 2520)]
[New Thread 0x7fffd0d47700 (LWP 2521)]
[New Thread 0x7fffb7fff700 (LWP 2526)]
[New Thread 0x7fffa4027700 (LWP 2533)]
[New Thread 0x7fffa3826700 (LWP 2534)]
Program received signal SIGSEGV, Segmentation fault. fault. 0x00007fffd2aae307 in ?? () from /usr/lib/fglrx/dri/fglrx_dri.so /usr/lib/fglrx/dri/fglrx_dri.so
(gdb) bt
Hi :)
done.
(gdb) run
[New Thread 0x7fffe5289700 (LWP 2511)]
[New Thread 0x7fffe4a88700 (LWP 2512)]
[New Thread 0x7fffdffff700 (LWP 2513)]
[New Thread 0x7fffd6a68700 (LWP 2515)]
[New Thread 0x7fffd6267700 (LWP 2516)]
[New Thread 0x7fffd5866700 (LWP 2517)]
[New Thread 0x7fffd4c43700 (LWP 2518)]
[New Thread 0x7fffc3fff700 (LWP 2522)]
[New Thread 0x7fffc37fe700 (LWP 2523)]
[New Thread 0x7fffc2ffd700 (LWP 2524)]
done.
(gdb) run
(gdb) bt
