Problem: Depth camera plugin does not show any coloured images.
Hi everybody,
I'm currently trying to attach a camera to a robot. While that works fine, it seems that I can only see the depth images it produces and not the RGB images it should (I think?) also produce. Below is the SDF code I use to define the sensor:
<sensor name="downward_cam_camera_sensor" type="depth">
  <pose>0 0 0 0 1.57079632679 0</pose>
  <update_rate>20</update_rate>
  <always_on>true</always_on>
    <horizontal_fov>1.745</horizontal_fov>
      <width>640</width>
      <height>480</height>
      <format>R8G8B8</format>
      <near>0.01</near>
      <far>100</far>
  <plugin name="downward_cam_camera_controller" filename="libgazebo_ros_depth_camera.so">
    <cameraName>downward_cam</cameraName>
    <alwaysOn>true</alwaysOn>
    <updateRate>20</updateRate>
    <imageTopicName>camera/image</imageTopicName>
    <depthImageTopicName>camera/depth_image</depthImageTopicName>
    <cameraInfoTopicName>camera/camera_info</cameraInfoTopicName>
    <depthCameraInfoTopicName>camera/depth_camera_info</depthCameraInfoTopicName>
    <depthImageCameraInfoTopicName>camera/depth_image_camera_info</deptImageCameraInfoTopicName>
    <frameName>downward_cam_optical_frame</frameName>
    <interface:camera name="downward_cam_camera_iface"/>
When I check out the depth image with the command:
rosrun image_view image_view image:=/downward_cam/camera/depth_image
then I see a grey scale image which is fine. But when I check the other topic:
rosrun image_view image_view image:=/downward_cam/camera/image
Nothing appears. I checked if that topic exists, which is the case. But when I check if any messages are coming though:
rostopic echo /downward_cam/camera/image
no messages appear...
Does anybody have an idea how I can extract coloured images from the camera? Am I using the wrong plugin, are my parameters wrong?
Any help is appreciated, thanks!
Bram
