Friction insufficient for grasping simulation
For an application where a manipulator picks up a cylinder I have created a primitive gripper with a ROS SimpleTransmission and EffortJointInterface. The Gazebo model for the cylinder comes from an STL file. This is using Gazebo 9 and ROS Kinetic. In Gazebo the gripper can push the cylinder around but it does not pick it up; the cylinder just slides through the gripper as shown in the animation.
image description
I've changed the friction coefficients in both the gripper urdf and the cylinder sdf to 99999.9. I also reduced the mass of the cylinder. The effort limit on the joint I set to 999999.9, just to try to get it to grip really hard.
Part of the gripper urdf and the entire cylinder sdf are pasted below the animation. Can you tell me what I need to do to get a gripper to pick up this object?
Part of gripper urdf
  <!-- Prismatic joint -->
  <joint name="gripper_joint" type="prismatic">
    <origin xyz="${2 * gripper_side_block_width + gripper_thickness} 0 0" rpy="0 0 0" />
    <parent link="gripper_wide_block_p" />
    <child link="gripper_wide_block_d" />
    <limit effort="999999.9" lower="-100" upper="100" velocity="0.5"/>
  <transmission name="gripper_joint_transmission">
    <joint name="gripper_joint">
      <hardwareInterface>hardware_interface/EffortJointInterface</hardwareInterface>
    <actuator name="gripper_joint_motor">
    </actuator>
  </transmission>
  <!-- High friction on gripper -->
  <gazebo>
    <mu1>99999.9</mu1>
    <mu2>99999.9</mu2>
</robot>
Cylinder sdf
<sdf version='1.6'>
  <model name='Cone100'>
    <link name='Cone100'>
        <pose frame=''>0 0 0.14605 0 -0 0</pose>
        <mass>0.1</mass>
          <ixx>0.0161005</ixx>
          <ixy>5.1652e-35</ixy>
          <ixz>5.85205e-35</ixz>
          <iyy>0.0161005</iyy>
          <iyz>5.04266e-19</iyz>
          <izz>0.0135779</izz>
      <collision name='Cone100_collision'>
    <surface>
      <friction>
        <ode>
          <mu>99999.9</mu>
          <mu2>99999.9</mu2>
        </ode>
      </friction>
      <!-- Change max_vel and/or min_depth to keep cones from "bouncing" -->
      <contact>
        <ode>
          <!--max_vel>0</max_vel-->
          <min_depth>0.001</min_depth>
        </ode>
      </contact>
    </surface>
        <pose frame=''>0 0 0 1.5708 -0 0</pose>
          <mesh>
            <scale>1 1 1</scale>
            <uri>model://Cone100/meshes/Cone100.STL</uri>
          </mesh>
      <visual name='Cone100_visual'>
          <mesh>
          </mesh>
image description
    </actuator>
  </transmission>
  <gazebo>
    <mu1>99999.9</mu1>
    <mu2>99999.9</mu2>
</robot>
Cylinder sdf
<sdf version='1.6'>
        <mass>0.1</mass>
    <surface>
      <friction>
        <ode>
          <mu>99999.9</mu>
          <mu2>99999.9</mu2>
        </ode>
      </friction>
      <contact>
        <ode>
        </ode>
      </contact>
    </surface>
          <mesh>
          </mesh>
          <mesh>
          </mesh>
Friction insufficient for in grasping simulation
image description
I've changed the friction coefficients in both the gripper urdf and the cylinder sdf to 99999.9. 1.0 (this question used to say 99999.9 but following an answer below I made them 1.0 instead). I also reduced the mass of the cylinder. The effort limit on the joint I set to 999999.9, just to try to get it to grip really hard.hard. The integral gain is 1.0 and the robot pauses after gripping to give time for the error integral to grow (the cylinder keeps the gripper from closing all the way).
    </actuator>
  </transmission>
  <gazebo>
    <mu1>99999.9</mu1>
    <mu2>99999.9</mu2>
<gazebo reference="gripper_wide_block_p">
    <mu1>1.0</mu1>
    <mu2>1.0</mu2>
    <minDepth>0.003</minDepth>
    <maxVel>0</maxVel>
  <gazebo reference="gripper_wide_block_d">
    <mu1>1.0</mu1>
    <mu2>1.0</mu2>
    <maxVel>0</maxVel>
</robot>
Cylinder sdf
<sdf version='1.6'>
        <mass>0.1</mass>
    <surface>
      <friction>
        <ode>
          <mu>99999.9</mu>
          <mu2>99999.9</mu2>
<mu>1.0</mu>
          <mu2>1.0mu2>
        </ode>
      </friction>
      <contact>
        <ode>
        </ode>
      </contact>
    </surface>
          <mesh>
          </mesh>
          <mesh>
          </mesh>
Friction insufficient in grasping simulation
image description
I've changed the friction coefficients in both the gripper urdf and the cylinder sdf to 1.0 100.0 (this question used to say 99999.9 but following an answer below I made them 1.0 100.0 instead). I also reduced the mass of the cylinder. The effort limit on the joint I set to 999999.9, just to try to get it to grip really hard. The integral gain is 1.0 and the robot pauses after gripping to give time for the error integral to grow (the cylinder keeps the gripper from closing all the way).
    </actuator>
  </transmission>
    <mu1>1.0</mu1>
    <mu2>1.0</mu2>
<mu1>100.0</mu1>
    <mu2>100.0</mu2>
    <maxVel>0</maxVel>
    <mu1>1.0</mu1>
    <mu2>1.0</mu2>
<mu1>100.0</mu1>
    <mu2>100.0</mu2>
    <maxVel>0</maxVel>
</robot>
Cylinder sdf
<sdf version='1.6'>
        <mass>0.1</mass>
    <surface>
      <friction>
        <ode>
          <mu>1.0</mu>
          <mu2>1.0mu2>
<mu>100.0</mu>
          <mu2>100.0mu2>
        </ode>
      </friction>
      <contact>
        <ode>
        </ode>
      </contact>
    </surface>
          <mesh>
          </mesh>
          <mesh>
          </mesh>
image description
I've changed the friction coefficients in both the gripper urdf and the cylinder sdf to 100.0 (this question used to say 99999.9 but following an answer below I made them 100.0 instead). I also reduced the mass of the cylinder. The effort limit on the joint I set to 999999.9, just to try to get it to grip really hard. The integral gain is 1.0 and the robot pauses after gripping to give time for the error integral to grow (the cylinder keeps the gripper from closing all the way).
Update: Because I thought perhaps there was insufficient contact between the cylinder and flat gripper, I changed the object model to a block and made the gripper taller. Like the cylinder, the block has mass of 0.1 and friction coefficients of 100. This animation shows that the result is the same as before.
image description
    </actuator>
  </transmission>
    <mu1>100.0</mu1>
    <mu2>100.0</mu2>
    <maxVel>0</maxVel>
    <mu1>100.0</mu1>
    <mu2>100.0</mu2>
    <maxVel>0</maxVel>
</robot>
Cylinder sdf
<sdf version='1.6'>
        <mass>0.1</mass>
    <surface>
      <friction>
        <ode>
          <mu>100.0</mu>
          <mu2>100.0mu2>
        </ode>
      </friction>
      <contact>
        <ode>
        </ode>
      </contact>
    </surface>
          <mesh>
          </mesh>
          <mesh>
          </mesh>
image description
image description
    </actuator>
  </transmission>
    <mu1>100.0</mu1>
    <mu2>100.0</mu2>
    <maxVel>0</maxVel>
    <mu1>100.0</mu1>
    <mu2>100.0</mu2>
    <maxVel>0</maxVel>
</robot>
Cylinder sdf
<sdf version='1.6'>
        <mass>0.1</mass>
    <surface>
      <friction>
        <ode>
          <mu>100.0</mu>
          <mu2>100.0mu2>
<mu2>100.0</mu2>
        </ode>
      </friction>
      <contact>
        <ode>
        </ode>
      </contact>
    </surface>
          <mesh>
          </mesh>
          <mesh>
          </mesh>
image description
image description
Here is the result of View --> Contacts.
image description
    </actuator>
  </transmission>
    <mu1>100.0</mu1>
    <mu2>100.0</mu2>
    <maxVel>0</maxVel>
    <mu1>100.0</mu1>
    <mu2>100.0</mu2>
    <maxVel>0</maxVel>
</robot>
Cylinder sdf
<sdf version='1.6'>
        <mass>0.1</mass>
    <surface>
      <friction>
        <ode>
          <mu>100.0</mu>
          <mu2>100.0</mu2>
        </ode>
      </friction>
      <contact>
        <ode>
        </ode>
      </contact>
    </surface>
          <mesh>
          </mesh>
          <mesh>
          </mesh>
Update 2
Following some advice below I changed the ROS controller from EffortJointInterface to PositionJointInterface and this seems to be a step in the right direction, the object moves vertically a little bit, but it still does not grasp properly. I've varied the joint effort limit and proportional gain but it seems like sometimes the force is too high, causing instability as shown in the animation, or else it is too low and the object just slips out of the gripper. Parameters I've varied are mu, mu2, kp, kd, min_depth, and max_vel, even restoring them to their default values; all to no good effect.
image description
Original question
image description
image description
image description
    </actuator>
  </transmission>
    <mu1>100.0</mu1>
    <mu2>100.0</mu2>
    <maxVel>0</maxVel>
    <mu1>100.0</mu1>
    <mu2>100.0</mu2>
    <maxVel>0</maxVel>
</robot>
Cylinder sdf
<sdf version='1.6'>
        <mass>0.1</mass>
    <surface>
      <friction>
        <ode>
          <mu>100.0</mu>
          <mu2>100.0</mu2>
        </ode>
      </friction>
      <contact>
        <ode>
        </ode>
      </contact>
    </surface>
          <mesh>
          </mesh>
          <mesh>
          </mesh>
Update 2
Following some advice below I changed the ROS controller from EffortJointInterface to PositionJointInterface EffortJointInterface to PositionJointInterface and this seems to be a step in the right direction, the object moves vertically a little bit, but it still does not grasp properly. I've varied the joint effort limit and proportional gain but it seems like sometimes the force is too high, causing instability as shown in the animation, or else it is too low and the object just slips out of the gripper. Parameters I've varied are mu, mu2, kp, kd, min_depth, and max_vel, even restoring them to their default values; all to no good effect.
image description
Original question
image description
image description
image description
    </actuator>
  </transmission>
    <mu1>100.0</mu1>
    <mu2>100.0</mu2>
    <maxVel>0</maxVel>
    <mu1>100.0</mu1>
    <mu2>100.0</mu2>
    <maxVel>0</maxVel>
</robot>
Cylinder sdf
<sdf version='1.6'>
        <mass>0.1</mass>
    <surface>
      <friction>
        <ode>
          <mu>100.0</mu>
          <mu2>100.0</mu2>
        </ode>
      </friction>
      <contact>
        <ode>
        </ode>
      </contact>
    </surface>
          <mesh>
          </mesh>
          <mesh>
          </mesh>
