[Mac OS X] Gazebo does not launch after compiling from source
I am trying to get Gazebo to run on Mac OS X High Sierra. Gazebo works great when I install everything using homebrew, but I can't get it to work with a build from source. The compilation and install seem to complete successfully, but nothing happens when I run the gazebo executable from the terminal. Here are the steps I've taken:
brew install caskroom/cask/xquartz
brew tap osrf/simulation
brew install gazebo9 --only-dependencies
brew install mercurial
hg clone https://bitbucket.org/osrf/gazebo /tmp/gazebo
cd /tmp/gazebo
hg up gazebo-9
cmake ../
make -j4
make install
gazebo --verbose
Which produces the following output:
Gazebo multi-robot simulator, version 9.0.0
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 10.10.195.121
but then nothing happens... I also tried starting the Gazebo server
gzserver
but it just segfaults... So I ran the debugger and it halts on line 442 of the RenderEngine.cc file where it tries to load an OGRE plugin.
 this->dataPtr->root->loadPlugin(*piter+extension);
image description
I am not sure how to proceed from here. Any help would be greatly appreciated.
cd /tmp/gazebo
hg up gazebo-9
cmake ../
make -j4
make install
gazebo --verbose
gzserver
image description
cd /tmp/gazebo
hg up gazebo-9
cmake ../
make -j4
make install
gazebo --verbose
gzserver
image description
cd /tmp/gazebo
hg up gazebo-9
cmake ../
make -j4
make install
gazebo --verbose
gzserver
image description
cd /tmp/gazebo
hg up gazebo-9
cmake ../
make -j4
make install
gazebo --verbose
gzserver
image description
[Mac OS X] Gazebo 9 does not launch after compiling from source
cd /tmp/gazebo
hg up gazebo-9
cmake -DCMAKE_BUILD_TYPE=Debug ../
make -j4
make install
gazebo --verbose
gzserver
image description
cd /tmp/gazebo
hg up gazebo-9
make -j4
make install
source /usr/local/share/gazebo/setup.sh
gazebo --verbose
gzserver
image description
cd /tmp/gazebo
hg up gazebo-9
gazebo9
make -j4
make install
gazebo --verbose
gzserver
image description
cd /tmp/gazebo
hg up gazebo9
make -j4
make install
gazebo --verbose
gzserver
image description
I am trying to get Gazebo to run on Mac OS X Sierra. Gazebo works great when I install everything using homebrew, but I can't get it to work with a build from source. The compilation and install seem to complete successfully, but nothing happens when I run the gazebo executable from the terminal. Here are the steps I've taken:
cd /tmp/gazebo
hg up gazebo9
make -j4
make install
gazebo --verbose
gzserver
image description
