Joint and sensor data spikes
I've been having trouble with spikes in force/torque sensor data. There are spikes in the joint velocity data also, but I haven't bothered too much about them until now when i'm trying to wrap control loops around force/torque sensor data. See the attached and labeled screenshot of some plots of the x/y/z forces from a force/torque sensor as well as a joint velocity signal from one of the joints.
Below are a few notes about my physics config that may be helpful,
  • physics iterations: 100
  • sor: 1.0
  • don't believe there are any self collisions happening
  • have tried raising iterations arbitrarily high and it doesn't help
  • have tuned sor and it doesn't help
  • all joints have implicit spring damper at 1
I have tweaked link inertia/mass to see if it's a poorly conditioned system for the physics and nothing i've done has had much of an affect.
If I thought I was just dealing with noise I would just put a filter on it and move on, but these spikes don't look like noise to me and i'm afraid to just ignore them and bandaid it with a filter.
One more note that may be helpful, i'm doing velocity control via the joint->SetVelocity call from the joint API.
image description
As a further test I remove my gazebo plugins call to joint->SetVelocity so the arms now just go slack and hang down and here's the same plot in that configuration,
image description
The large spikes are still there in the force/torque sensor data, but the joint velocity is now smooth with no spikes.
