Exception sending a message
I've installed ROS-Melodic (full desktop) with Gazebo 9 on 3 different PC: 2 of them are with Ubuntu 18.04 and third one with WSL Ubuntu 18.04 (Windows 10). After a fresh install I get Exception sending a message, which is being printed infinitely after starting gazebo (gzserver, roslaunch): image description
One more thing - I use gazebo via ssh or terminal (wsl), so there is no GUI.
Here is also a related question
Update:
I've noticed that the problem happens only when I open VPN connection. Here is the --verbos output on my local machine in WLS Ubuntu 18.04 (the same output is on remote PC with Ubuntu 18.04 over VPN and ssh)
ubuntu:~$ gzserver --verboss
shared memfd open() failed: Function not implemented
ALSA lib confmisc.c:767:(parse_card) cannot find card '0'
ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1246:(snd_func_refer) error evaluating name
ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5007:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM default
AL lib: (EE) ALCplaybackAlsa_open: Could not open playback device 'default': No such file or directory
Update:
--verbose
Gazebo multi-robot simulator, version 9.0.0
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 127.0.0.1
Exception sending a messageException sending a message
[Err] [OpenAL.cc:84] Unable to open audio device[default]
 Audio will be disabled.
[Wrn] [Time.cc:439] Sleep time is larger than clock resolution, skipping sleep
xception sending a message33m
Update:
I've noticed that the problem happens only when I open VPN VPN connection. Here is the --verbos--verbose output on my local machine in WLS Ubuntu 18.04 (the same output is on remote PC with Ubuntu 18.04 over VPN and ssh)
ubuntu:~$ gzserver --verbose
