Warning [parser.cc:536] XML Attribute[***] in element[***] not defined in SDF, ignoring.
I try to set inertial parameters of the imported object in sdf. It seems it works for other people, however for me it results in warnings. Neither mass, nor moments of inertia, nor CoM are set in Gazebo. I use ROS Kinetic and Gazebo 7.0.0 under Ubuntu 16.04. What could be a problem here?
sdf file
<?xml version="1.0" ?>
<sdf version="1.6">
  <model name="kitchen_spatula">
    <static>false</static>
      <pose>0 0 0 0 0 0</pose>
    <origin rpy="0 0 0" xyz="0.13606 0.00000 0.02002"/>
    <mass value="0.14867"/>
    <inertia ixx="0.00016"
             ixy="0.00000"
             ixz="0.00030"
             iyy="0.00113"
             iyz="0.00000"
             izz="0.00106"/>
      <mesh>
        <uri>model://kitchen_spatula/low_poly_paddle.STL</uri>
        <!-- Whatever unit you use in stl, it will be treated as meters by Gazebo:
        http://answers.gazebosim.org/question/8294/mesh-scale-huge-for-stl-file/ -->
        <scale>0.001 0.001 0.001</scale>
      </mesh>
      <script>
        <name>Gazebo/Orange</name>
      </script>
      <mesh>
      </mesh>
output:
[INFO] [1543493481.499131, 0.000000]: Loading model XML from ros parameter
[INFO] [1543493481.500796, 0.000000]: Waiting for service /gazebo/spawn_urdf_model
Warning [parser.cc:778] XML Element[origin], child of element[inertial] not defined in SDF. Ignoring[origin]. You may have an incorrect SDF file, or an sdformat version that doesn't support this element.
Warning [parser.cc:536] XML Attribute[value] in element[mass] not defined in SDF, ignoring.
Warning [parser.cc:536] XML Attribute[ixx] in element[inertia] not defined in SDF, ignoring.
Warning [parser.cc:536] XML Attribute[ixy] in element[inertia] not defined in SDF, ignoring.
Warning [parser.cc:536] XML Attribute[ixz] in element[inertia] not defined in SDF, ignoring.
Warning [parser.cc:536] XML Attribute[iyy] in element[inertia] not defined in SDF, ignoring.
Warning [parser.cc:536] XML Attribute[iyz] in element[inertia] not defined in SDF, ignoring.
Warning [parser.cc:536] XML Attribute[izz] in element[inertia] not defined in SDF, ignoring.
[ INFO] [1543493482.285987182, 0.021000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1543493482.315061083, 0.049000000]: Physics dynamic reconfigure ready.
