Robot not visible after spawning in Gazebo
Hello, I am facing the following problem: My .urdf robot spawned successfully but is NOT visible in Gazebo.
To spawn the robot, I typed in the terminal the following command:
rosrun gazebo_ros spawn_model -file `rospack find panda_description`/urdf/panda_arm_hand.urdf -urdf -x 0 -y 0 -z 1 -model panda
This is the response from the terminal:
SpawnModel script started
[INFO] [1546954850.970203, 0.000000]: Loading model XML from file
[INFO] [1546954850.971724, 0.000000]: Waiting for service /gazebo/spawn_urdf_model
[INFO] [1546954850.975910, 0.000000]: Calling service /gazebo/spawn_urdf_model
[INFO] [1546954851.108377, 24.346000]: Spawn status: SpawnModel: Successfully spawned entity
When I open Gazebo the robot "panda" ist written in the structure tree on the left side but in the simulation not visible.
This is my file hierarchy:
../catkin_ws/src
/panda_description
    CMakeLists.txt
    package.xml
    /meshes
        /collision
            finger.stl
            hand.stl
            link0.stl
            link1.stl
            link2.stl
            link3.stl
            link4.stl
            link5.stl
            link6.stl
            link7.stl
        /visual
            finger.dae
            hand.dae
            link0.dae
            link1.dae
            link2.dae
            link3.dae
            link4.dae
            link5.dae
            link6.dae
            link7.dae
    /urdf
        panda_arm_hand.urdf
The .urdf is converted from an .urdf.xacro file.
The panda_arm_hand.urdf file:
<?xml version="1.0" ?>
<!-- |    This document was autogenerated by xacro from panda_arm_hand.urdf.xacro      | -->
<!-- |    EDITING THIS FILE BY HAND IS NOT RECOMMENDED                                 | -->
<robot name="panda" xmlns:xacro="http://www.ros.org/wiki/xacro">
  <link name="panda_link0">
    <visual>
        <mesh filename="package://franka_description/meshes/visual/link0.dae"/>
    <collision>
        <mesh filename="package://franka_description/meshes/collision/link0.stl"/>
  <link name="panda_link1">
    <visual>
        <mesh filename="package://franka_description/meshes/visual/link1.dae"/>
    <collision>
        <mesh filename="package://franka_description/meshes/collision/link1.stl"/>
  <joint name="panda_joint1" type="revolute">
    <safety_controller k_position="100.0" k_velocity="40.0" soft_lower_limit="-2.8973" soft_upper_limit="2.8973"/>
    <origin rpy="0 0 0" xyz="0 0 0.333"/>
    <parent link="panda_link0"/>
    <child link="panda_link1"/>
    <axis xyz="0 0 1"/>
    <limit effort="87" lower="-2.8973" upper="2.8973" velocity="2.1750"/>
  <link name="panda_link2">
    <visual>
        <mesh filename="package://franka_description/meshes/visual/link2.dae"/>
    <collision>
        <mesh filename="package://franka_description/meshes/collision/link2.stl"/>
  <joint name="panda_joint2" type="revolute">
    <safety_controller k_position="100.0" k_velocity="40.0" soft_lower_limit="-1.7628" soft_upper_limit="1.7628"/>
    <origin rpy="-1.57079632679 0 0" xyz="0 0 0"/>
    <parent link="panda_link1"/>
    <child link="panda_link2"/>
    <axis xyz="0 0 1"/>
    <limit effort="87" lower="-1.7628" upper="1.7628" velocity="2.1750"/>
  <link name="panda_link3">
    <visual>
        <mesh filename="package://franka_description/meshes/visual/link3.dae"/>
    <collision>
        <mesh filename="package://franka_description/meshes/collision/link3.stl"/>
  <joint name="panda_joint3" type="revolute">
    <origin rpy="1.57079632679 0 0" xyz="0 -0.316 0"/>
    <parent link="panda_link2"/>
    <child link="panda_link3"/>
    <axis xyz="0 0 1"/>
  <link name="panda_link4">
    <visual>
        <mesh filename="package://franka_description/meshes/visual/link4.dae"/>
    <collision>
        <mesh filename="package://franka_description/meshes/collision/link4.stl"/>
  <joint name="panda_joint4" type="revolute">
    <safety_controller k_position="100.0" k_velocity="40.0" soft_lower_limit="-3.0718" soft_upper_limit="-0.0698"/>
    <origin rpy="1.57079632679 0 0" xyz="0.0825 0 0"/>
    <parent link="panda_link3"/>
    <child link="panda_link4"/>
    <axis xyz="0 0 1"/>
    <limit effort="87" lower="-3.0718" upper="-0.0698" velocity="2.1750"/>
  <link name="panda_link5">
    <visual>
        <mesh filename="package://franka_description/meshes/visual/link5.dae"/>
    <collision>
        <mesh filename="package://franka_description/meshes/collision/link5.stl"/>
  <joint name="panda_joint5" type="revolute">
    <origin rpy="-1.57079632679 0 0" xyz="-0.0825 0.384 0"/>
    <parent link="panda_link4"/>
    <child link="panda_link5"/>
    <axis xyz="0 0 1"/>
    <limit effort="12" lower="-2.8973" upper="2.8973" velocity="2.6100"/>
  <link name="panda_link6">
    <visual>
        <mesh filename="package://franka_description/meshes/visual/link6.dae"/>
    <collision>
        <mesh filename="package://franka_description/meshes/collision/link6.stl"/>
  <joint name="panda_joint6" type="revolute">
    <safety_controller k_position="100.0" k_velocity="40.0" soft_lower_limit="-0.0175" soft_upper_limit="3.7525"/>
    <origin rpy="1.57079632679 0 0" xyz="0 0 0"/>
    <parent link="panda_link5"/>
    <child link="panda_link6"/>
    <axis xyz="0 0 1"/>
    <limit effort="12" lower="-0.0175" upper="3.7525" velocity="2.6100"/>
  <link name="panda_link7">
    <visual>
        <mesh filename="package://franka_description/meshes/visual/link7.dae"/>
    <collision>
        <mesh filename="package://franka_description/meshes/collision/link7.stl"/>
  <joint name="panda_joint7" type="revolute">
    <origin rpy="1.57079632679 0 0" xyz="0.088 0 0"/>
    <parent link="panda_link6"/>
    <child link="panda_link7"/>
    <axis xyz="0 0 1"/>
  <link name="panda_link8"/>
  <joint name="panda_joint8" type="fixed">
    <origin rpy="0 0 0" xyz="0 0 0.107"/>
    <parent link="panda_link7"/>
    <child link="panda_link8"/>
    <axis xyz="0 0 0"/>
  <joint name="panda_hand_joint" type="fixed">
    <parent link="panda_link8"/>
    <child link="panda_hand"/>
    <origin rpy="0 0 -0.785398163397" xyz="0 0 0"/>
  <link name="panda_hand">
    <visual>
        <mesh filename="package://franka_description/meshes/visual/hand.dae"/>
    <collision>
        <mesh filename="package://franka_description/meshes/collision/hand.stl"/>
  <link name="panda_leftfinger">
    <visual>
        <mesh filename="package://franka_description/meshes/visual/finger.dae"/>
    <collision>
        <mesh filename="package://franka_description/meshes/collision/finger.stl"/>
  <link name="panda_rightfinger">
    <visual>
      <origin rpy="0 0 3.14159265359" xyz="0 0 0"/>
    <collision>
  <joint name="panda_finger_joint1" type="prismatic">
    <parent link="panda_hand"/>
    <child link="panda_leftfinger"/>
    <origin rpy="0 0 0" xyz="0 0 0.0584"/>
    <axis xyz="0 1 0"/>
    <limit effort="20" lower="0.0" upper="0.04" velocity="0.2"/>
  <joint name="panda_finger_joint2" type="prismatic">
    <child link="panda_rightfinger"/>
    <axis xyz="0 -1 0"/>
    <mimic joint="panda_finger_joint1"/>
</robot>
My first thought was that I have to manually change "franka_description" to "panda_description" but when I do so it still dont work. The package "franka_description" (it is shown with the command rospack list) is installed so I think it should work with this.
