Error in REST request for accessing api.ignition.org
Hi, I am trying to run an existing environment in Gazebo for my ROS project. Basically I need to do some robot navigation in a predefined environment. After installing all the dependencies and doing the setup of the workspace I try to roslaunch the environment. However, Gazebo opens up an empty environment. That is a problem since there ought to be a large floor with a couple of offices and some obstacles for the robot, as well as the robot itself. I checked the startup initialization and there seems to be a problem with accessing api.ignition.org, as shown in the picture below.
image description
I tried pinging the server but got no response and after googling it, I realized it was a large storage of models for gazebo, which got me to the conclusion that this error was responsible for an empty environment opening in Gazebo.
I am new to Gazebo and have only a slight experience with ROS so I apologize if I didn't use correct terms for explaining my problem. I wonder if someone else had a similar problem and if so, is there a way to fix this. I am using ROS melodic version 1.14.3 and Gazebo version 9.0.0
Thank you for your time and help.
