Cannot Compile Custom Plugins
I went through the Write-a-Plugin tutorials and decided to try and write one to get the process down. To start, I just tried to replace some words in the tutorial code to see if I was understanding it correctly. It turns out I'm not, and I'm very confused as to what's going wrong as I get this when I run the 'make' command in the build directory. The tutorials run without error, but when I change the class name, the compiler no longer recognizes it:
/home/joey/Gazebo Stuff/bart_world_plugin/plugin_test.cc:10:3: error: expected class-name before ‘{’ token
In file included from /usr/include/gazebo-9/gazebo/common/common.hh:36:0,
                 from /usr/include/gazebo-9/gazebo/gazebo_core.hh:19,
                 from /usr/include/gazebo-9/gazebo/gazebo.hh:20,
                 from /home/joey/Gazebo Stuff/bart_world_plugin/plugin_test.cc:2:
/home/joey/Gazebo Stuff/bart_world_plugin/plugin_test.cc: In function ‘gazebo::ModelPlugin* gazebo::RegisterPlugin()’:
/usr/include/gazebo-9/gazebo/common/Plugin.hh:432:26: error: cannot convert ‘gazebo::PluginTest*’ to ‘gazebo::ModelPlugin*’ in return
     return new classname();\
/home/joey/Gazebo Stuff/bart_world_plugin/plugin_test.cc:37:3: note: in expansion of macro ‘GZ_REGISTER_MODEL_PLUGIN’
   GZ_REGISTER_MODEL_PLUGIN(PluginTest)
CMakeFiles/plugin_test.dir/build.make:62: recipe for target 'CMakeFiles/plugin_test.dir/plugin_test.cc.o' failed
make[2]: *** [CMakeFiles/plugin_test.dir/plugin_test.cc.o] Error 1
CMakeFiles/Makefile2:104: recipe for target 'CMakeFiles/plugin_test.dir/all' failed
make[1]: *** [CMakeFiles/plugin_test.dir/all] Error 2
Makefile:83: recipe for target 'all' failed
make: *** [all] Error 2
The file in question is based off model_push.cc; this is my "custom" plugin, plugin_test.cc where I only changed class name and the public name in what I believed to be the correct spots:
#include <functional>
#include <gazebo/gazebo.hh>
#include <ignition/math/Vector3.hh>
namespace gazebo
  class PluginTest : public PluginTestPlugin
      this->model = _parent;
      // simulation iteration.
          std::bind(&PluginTest::OnUpdate, this));
    public: void OnUpdate()
      // Apply a small linear velocity to the model.
      this->model->SetLinearVel(ignition::math::Vector3d(0, 500, 0));
    // Pointer to the model
Here's CMakeLists.txt:
cmake_minimum_required(VERSION 2.8 FATAL_ERROR)
find_package(gazebo REQUIRED)
include_directories(${GAZEBO_INCLUDE_DIRS})
link_directories(${GAZEBO_LIBRARY_DIRS})
list(APPEND CMAKE_CXX_FLAGS "${GAZEBO_CXX_FLAGS}")
add_library(plugin_test SHARED plugin_test.cc)
target_link_libraries(plugin_test ${GAZEBO_LIBRARIES})
The only other thing I could find on the topic of a custom plugin not compiling was solved by adding another include, but that didn't seem to have an effect on my plugin.
