The joints rotate faster than their limits in Gazebo
Hi there. I write a model, consisting of several links and joints. The joints are revolute and I set the limit of one joint as:
<limit effort="1000.0" lower="-1.57" upper="1.57" velocity="0.5"/>
The "lower" and "upper" work well in Gazebo, however, the angular velocity sometimes is larger than 0.5 rad/s. To explain this, I set the rate as 20 Hz, than in each step the change of angle should be less than or equal to 0.5/20=0.025 rad/s. But sometimes it is larger than 0.5/20 in one step.
I appreciate your help. Thanks.
