COLLADA Mesh vs Box behavior difference
I am currently using Fuerte-Gazebo (Gazebo-1.0.2).
Given same exact values under <collision> <surface>. (literally all values are same including size) 1. simple box collada mesh 2. box from gazebo UI
They behave differently when I put a bowl/can on it. On collada model, it sort of bounces and jumps out. (even though all collision values are same) But on a same size box, objects will soon settle down.
What is causing behavior difference? Is there anything other than <collision> <surface> that plays the role?
Here are the values I copied from box generated from Gazebo client.
      <surface>
        <friction>
          <ode mu='2147483647.0' mu2='2147483647.0' fdir1='0.0 0.0 0.0' slip1='0.0' slip2='0.0'/>
        </friction>
        <bounce restitution_coefficient='0.0' threshold='1000000.0'/>
        <contact>
          <ode soft_cfm='0.0' soft_erp='0.20' kp='2147483647.0' kd='1.00' max_vel='5.00' min_depth='0.00'/>
        </contact>
      </surface>
      <surface>
        <friction>
        </friction>
        <contact>
        </contact>
      </surface>
