DRC Sim crashes post installation for 2.4 onwards
Hi, I have been facing crash of DRC Sim ever since the new versions were launched. DRC Sim 2.4 onwards installing on clean 64 bit Ubuntu Quantal and on running the launch file gives the error below: I did solve it last time by installing the libraries but crashed and the same thing started again. * /multisense_sl/camera/stereo_proc/approximate_sync * /multisense_sl/camera/stereo_proc/disparity_range * /multisense_sl_robot_state_publisher/publish_frequency * /robot_description * /rosdistro * /rosversion * /tf2_buffer_server/buffer_size * /use_sim_time
NODES /multisense_sl/camera/ stereo_proc (stereo_image_proc/stereo_image_proc) / atlas_robot_state_publisher (robot_state_publisher/state_publisher) gazebo (atlas_utils/run_gazebo) multisense_sl_robot_state_publisher (robot_state_publisher/state_publisher) tf2_buffer_server (tf2_ros/buffer_server)
auto-starting new master process[master]: started with pid [28022] ROS_MASTER_URI=http://localhost:11311
setting /run_id to 5709e55c-acb8-11e2-931b-4c809313301c process[rosout-1]: started with pid [28035] started core service [/rosout] process[gazebo-2]: started with pid [28049] process[atlas_robot_state_publisher-3]: started with pid [28051] process[multisense_sl_robot_state_publisher-4]: started with pid [28052] process[tf2_buffer_server-5]: started with pid [28068] process[multisense_sl/camera/stereo_proc-6]: started with pid [28121] Gazebo multi-robot simulator, version 1.7.1 Copyright (C) 2013 Open Source Robotics Foundation. Released under the Apache 2 License. http://gazebosim.org
Msg Waiting for master.Warning [parser.cc:361] Converting a deprecated SDF source[/usr/share/drcsim-2.5/worlds/atlas.world]. Warning [Converter.cc:58] Version[1.2] to Version[1.4] Please use the gzsdf tool to update your SDF files. $ gzsdf convert [sdf_file] Warning [ModelDatabase.cc:299] Getting models from[http://gazebosim.org/models/]. This may take a few seconds. [rospack] Error: the rosdep view is empty: call 'sudo rosdep init' and 'rosdep update' terminate called after throwing an instance of 'pluginlib::LibraryLoadException' what(): rospack could not find the nodelet package containing nodelet::Nodelet ......[multisense_sl/camera/stereo_proc-6] process has died [pid 28121, exit code -6, cmd /opt/ros/groovy/lib/stereo_image_proc/stereo_image_proc __name:=stereo_proc __log:=/home/sudip/.ros/log/5709e55c-acb8-11e2-931b-4c809313301c/multisense_sl-camera-stereo_proc-6.log]. log file: /home/sudip/.ros/log/5709e55c-acb8-11e2-931b-4c809313301c/multisense_sl-camera-stereo_proc-6*.log ...............Warning [parser.cc:377] SDF has no <sdf> element in file[/usr/share/drcsim-2.5/gazebo_models/atlas_description/atlas/atlas.urdf] Dbg [pelvis] has no parent joint Warning [parser_urdf.cc:1158] urdf2gazebo: link[left_camera_optical_frame] has no inertia, parent joint [left_camera_optical_frame_joint] ignored .Warning [parser_urdf.cc:1163] urdf2gazebo: link[left_camera_optical_frame] has no inertia, not modeled in gazebo Warning [parser_urdf.cc:1158] urdf2gazebo: link[right_camera_optical_frame] has no inertia, parent joint [right_camera_optical_frame_joint] ignored .Warning [parser_urdf.cc:1163] urdf2gazebo: link[right_camera_optical_frame] has no inertia, not modeled in gazebo Warning [parser.cc:286] parse from urdf file [/usr/share/drcsim-2.5/gazebo_models/atlas_description/atlas/atlas.urdf]. Msg Waiting for master Msg Connected to gazebo master @ http://127.0.0.1:11345 Msg Publicized address: 192.168.0.11 ^C[tf2_buffer_server-5] killing on exit [multisense_sl_robot_state_publisher-4] killing on exit [atlas_robot_state_publisher-3] killing on exit [gazebo-2] killing on exit
Error [ConnectionManager.cc:88] Connection Manager is not running Dbg camera(0) name [default::left(0)] Dbg camera(1) name [default::right(1)] Error [VRCScoringPlugin.cc:68] VRCScoringPlugin: unknown world name "default"; not scoring.[ INFO] [1366791874.668447491]: drc vehicle not found. starting RT Setup trying to create VMC. Constructing joint controllers Finished RT setup [rospack] Error: the rosdep view is empty: call 'sudo rosdep init' and 'rosdep update' terminate called after throwing an instance of 'pluginlib::LibraryLoadException' what(): rospack could not find the image_transport package containing image_transport::PublisherPlugin ^CWarning [gazebo_main.cc:57] escalating to SIGKILL on server [rosout-1] killing on exit [master] killing on exit shutting down processing monitor... ... shutting down processing monitor complete done
click to hide/show revision 2
No.2 Revision
Hi, I have been facing crash of DRC Sim ever since the new versions were launched. DRC Sim 2.4 onwards installing on clean 64 bit Ubuntu Quantal and on running the launch file gives the error below: I did solve it last time by installing the libraries but crashed and the same thing started again. again.
 * /rosdistro
 * /rosversion
 * /use_sim_time
/use_sim_time NODES /multisense_sl/camera/ stereo_proc (stereo_image_proc/stereo_image_proc) / atlas_robot_state_publisher (robot_state_publisher/state_publisher) gazebo (atlas_utils/run_gazebo) multisense_sl_robot_state_publisher (robot_state_publisher/state_publisher) tf2_buffer_server (tf2_ros/buffer_server)
(tf2_ros/buffer_server) auto-starting new master process[master]: started with pid [28022] ROS_MASTER_URI=http://localhost:11311
ROS_MASTER_URI=http://localhost:11311 setting /run_id to 5709e55c-acb8-11e2-931b-4c809313301c process[rosout-1]: started with pid [28035] started core service [/rosout] process[gazebo-2]: started with pid [28049] process[atlas_robot_state_publisher-3]: started with pid [28051] process[multisense_sl_robot_state_publisher-4]: started with pid [28052] process[tf2_buffer_server-5]: started with pid [28068] [ WARN] [1366791852.298208300]: You've passed in true for auto_start for the C++ action server at [/tf2_buffer_server]. You should always pass in false to avoid race conditions. process[multisense_sl/camera/stereo_proc-6]: started with pid [28121] Gazebo multi-robot simulator, version 1.7.1 Copyright (C) 2013 Open Source Robotics Foundation. Released under the Apache 2 License. http://gazebosim.org
http://gazebosim.org Gazebo multi-robot simulator, version 1.7.1 Copyright (C) 2013 Open Source Robotics Foundation. Released under the Apache 2 License. http://gazebosim.org
http://gazebosim.org Msg Waiting for master.Warning [parser.cc:361] Converting a deprecated SDF source[/usr/share/drcsim-2.5/worlds/atlas.world]. Warning [Converter.cc:58] Version[1.2] to Version[1.4] Please use the gzsdf tool to update your SDF files. $ gzsdf convert [sdf_file] Warning [ModelDatabase.cc:299] Getting models from[http://gazebosim.org/models/]. This may take a few seconds. [rospack] Error: the rosdep view is empty: call 'sudo rosdep init' and 'rosdep update' [librospack]: error while executing command terminate called after throwing an instance of 'pluginlib::LibraryLoadException' what(): rospack could not find the nodelet package containing nodelet::Nodelet ......[multisense_sl/camera/stereo_proc-6] process has died [pid 28121, exit code -6, cmd /opt/ros/groovy/lib/stereo_image_proc/stereo_image_proc __name:=stereo_proc __log:=/home/sudip/.ros/log/5709e55c-acb8-11e2-931b-4c809313301c/multisense_sl-camera-stereo_proc-6.log]. log file: /home/sudip/.ros/log/5709e55c-acb8-11e2-931b-4c809313301c/multisense_sl-camera-stereo_proc-6*.log ...............Warning [parser.cc:377] SDF has no <sdf> element in file[/usr/share/drcsim-2.5/gazebo_models/atlas_description/atlas/atlas.urdf] Dbg [pelvis] has no parent joint Warning [parser_urdf.cc:1158] urdf2gazebo: link[left_camera_optical_frame] has no inertia, parent joint [left_camera_optical_frame_joint] ignored .Warning [parser_urdf.cc:1163] urdf2gazebo: link[left_camera_optical_frame] has no inertia, not modeled in gazebo Warning [parser_urdf.cc:1158] urdf2gazebo: link[right_camera_optical_frame] has no inertia, parent joint [right_camera_optical_frame_joint] ignored .Warning [parser_urdf.cc:1163] urdf2gazebo: link[right_camera_optical_frame] has no inertia, not modeled in gazebo Warning [parser.cc:286] parse from urdf file [/usr/share/drcsim-2.5/gazebo_models/atlas_description/atlas/atlas.urdf]. Msg Waiting for master Msg Connected to gazebo master @ http://127.0.0.1:11345 Msg Publicized address: 192.168.0.11 ^C[tf2_buffer_server-5] killing on exit [multisense_sl_robot_state_publisher-4] killing on exit [atlas_robot_state_publisher-3] killing on exit [gazebo-2] killing on exit
exit Error [ConnectionManager.cc:88] Connection Manager is not running Dbg camera(0) name [default::left(0)] Dbg camera(1) name [default::right(1)] [ INFO] [1366791874.427791633]: Camera plugin missing <CxPrime>, defaults to 0 [ INFO] [1366791874.428154895]: Camera plugin missing <Cx>, defaults to 0 [ INFO] [1366791874.428204684]: Camera plugin missing <Cy>, defaults to 0 [ INFO] [1366791874.428267610]: Camera plugin missing <focalLength>, defaults to 0 [ INFO] [1366791874.428430757]: Camera plugin missing <CxPrime>, defaults to 0 [ INFO] [1366791874.428464401]: Camera plugin missing <Cx>, defaults to 0 [ INFO] [1366791874.428493780]: Camera plugin missing <Cy>, defaults to 0 [ INFO] [1366791874.428522076]: Camera plugin missing <focalLength>, defaults to 0 Error [VRCScoringPlugin.cc:68] VRCScoringPlugin: unknown world name "default"; not scoring.[ INFO] [1366791874.668447491]: drc vehicle not found. [ INFO] [1366791874.668932526]: fire_hose_model [fire_hose] not found [ INFO] [1366791874.670371270]: atlas/startup_mode not specified, default bdi_stand that takes 2.000000 seconds to finish. [ INFO] [1366791874.677349557]: set robot configuration done starting RT Setup trying to create VMC. Constructing joint controllers Finished RT setup [ INFO] [1366791874.998219106]: p3d plugin missing <frameName>, defaults to world [ INFO] [1366791874.998401944]: p3d plugin missing <xyzOffset>, defaults to 0s [ INFO] [1366791874.998507696]: p3d plugin missing <rpyOffset>, defaults to 0s [ INFO] [1366791874.998622019]: p3d plugin missing <gaussianNoise>, defaults to 0.0 [ INFO] [1366791875.007328958]: Loading MultiSense ROS node. [rospack] Error: the rosdep view is empty: call 'sudo rosdep init' and 'rosdep update' [librospack]: error while executing command terminate called after throwing an instance of 'pluginlib::LibraryLoadException' what(): rospack could not find the image_transport package containing image_transport::PublisherPlugin ^CWarning [gazebo_main.cc:57] escalating to SIGKILL on server [rosout-1] killing on exit [master] killing on exit shutting down processing monitor... ... shutting down processing monitor complete done
done
