What is the difference between a Plugin and a Sensor
Hello all,
In http://gazebosim.org/wiki/Tutorials/1.4/using_the_ros_plugins it says that "The imu sensor and the imu plugin are different because the ros plugin use a model plugin and not a sensor plugin."
What exactly is different between a plugin and a sensor? Can't we create camera plugin or camera sensor with the same behavior?
Thanks
