Cloudsim/Softlayer: gzclient fails to launch on OCU
After running on the local OCU:
. ros.bash
I have shell variables (printenv | grep GAZ)
GAZEBO_MASTER_URI=http://10.0.0.51:11345
GAZEBO_IP=11.8.0.2
The gzclient launch fails, on a machine that can happily run gazebo locally.
Gazebo multi-robot simulator, version 1.8.0
Copyright (C) 2013 Open Source Robotics Foundation.
http://gazebosim.org
Msg Waiting for master
Msg Connected to gazebo master @ http://10.0.0.51:11345
Msg Publicized address: 11.8.0.2
Exception [RenderEngine.cc:579] unable to find OpenGL rendering system. OGRE is probably installed incorrectly. Double check the OGRE cmake output, and make sure OpenGL is enabled.
Error [Rendering.cc:38] Failed to load the Rendering engine subsystem
Warning [ModelDatabase.cc:117] GAZEBO_MODEL_DATABASE_URI not set
Warning [ModelDatabase.cc:202] Unable to connect to model database using [//database.config]. Only locally installed models will be available.
Error [parser.cc:99] Unable to load file[]
Warning [parser.cc:499] XML Attribute[version] in element[sdf] not defined in SDF, ignoring.
Error [parser.cc:719] XML Element[model], child of element[sdf] not defined in SDF. Ignoring.[]
Warning [parser.cc:427] Unable to parse sdf element[]
Error [parser.cc:337] parse as sdf version 1.4 failed, should try to parse as old deprecated format
Error [SDF.cc:1646] Unable to parse sdf string[<sdf version="1.4"><model name="building_template_model"><pose>0 0 0.0 0 0 0</pose><link name="link"><collision name="collision"><geometry><box><size>1.0 1.0 1.0</size></box></geometry></collision><visual name="visual"><pose>0 0 0.0 0 0 0</pose><geometry><box><size>1.0 1.0 1.0</size></box></geometry><material><script><uri>file://media/materials/scripts/gazebo.material</uri><name>Gazebo/Grey</name></script></material></visual></link><static>true</static></model></sdf>]
Error [WindowManager.cc:96]  Unable to create the rendering window
Exception [WindowManager.cc:103] Unable to create the rendering window
Qt has caught an exception thrown from an event handler. Throwing
exceptions from an event handler is not supported in Qt. You must
reimplement QApplication::notify() and catch all exceptions there.
terminate called after throwing an instance of 'gazebo::common::Exception'
