Linking problem when compiling from source
Hi there!
I'm not sure what's going on, but when compiling Gazebo from source (default), the gazebo executable is missing some shared libraries.
$ gazebo
    gazebo: error while loading shared libraries: libgazebo_common.so.1: cannot open shared object file: No such file or directory
$ ldd /usr/local/bin/gazebo
    linux-vdso.so.1 =>  (0x00007fffdcd04000)
    libgazebo_common.so.1 => not found
    libgazebo_util.so.1 => not found
    libgazebo_sdf_interface.so.1 => not found
    libgazebo_transport.so.1 => not found
    libgazebo_physics.so.1 => not found
    libgazebo_sensors.so.1 => not found
    libgazebo_msgs.so.1 => not found
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fb95ff5a000)
    libtbb.so.2 => /usr/lib/libtbb.so.2 (0x00007fb95fd2c000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fb95fb28000)
    libprotobuf.so.7 => /usr/lib/libprotobuf.so.7 (0x00007fb95f839000)
    libgazebo_math.so.1 => not found
    libboost_thread.so.1.46.1 => /usr/lib/libboost_thread.so.1.46.1 (0x00007fb95f61f000)
    libboost_system.so.1.46.1 => /usr/lib/libboost_system.so.1.46.1 (0x00007fb95f41b000)
    libboost_program_options.so.1.46.1 => /usr/lib/libboost_program_options.so.1.46.1 (0x00007fb95f1b5000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fb95eeb5000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fb95ec9f000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fb95e8df000)
    /lib64/ld-linux-x86-64.so.2 (0x00007fb9601ac000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fb95e6c8000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fb95e3cc000)
I can get Gazebo running after adding /usr/local/lib to the LD_LIBRARY_PATH, but I have the feeling, that shouldn't be necessary.
Any idea what's wrong?
