[quick question] what is color descption and <image> in SDF?
hi
I have quesiton about the <image> tap. The <image> tap is under:
<sensor>
            <format>
                   Description:    (L8|R8G8B8|B8G8R8|BAYER_RGGB8|BAYER_BGGR8|BAYER_GBRG8|BAYER_GRBG8)
Required: 0    Type: string    Default: R8G8B8
If I want the color to be only black or white, which format should I choose?
Thank you all
[quick question] what is color descption and <image> <format> in SDF?
hi
I have quesiton about the <image> <format> tap. The <image> <format> tap is under:
<sensor>
            <format>
According to Gazebo Sdf documentation
                   Description:    Description of <format> :
Thank you all
