Model Plugin does not load
Hey guys,
I am trying to do the following:
run a world with a world plugin -> world plugin creates a model (also with plugin). If I create a sensor with a sensor plugin (dynamically with the world plugin) then the sensor plugin is loaded. The model plugin does not...
I tried multiple versions of gazebo (1.4, 1.6, 1.9). Can you give me an hint?
Here are some code snippets: Patebin
Hey guys,
run a world with a world plugin -> world plugin creates a model (also with plugin). If I create a sensor with a sensor plugin (dynamically with the world plugin) then the sensor plugin is loaded. The model plugin does is not...
Hey guys,
run a world with a world plugin -> world plugin creates a model (also with plugin). If I create a sensor with a sensor plugin (dynamically with the world plugin) then the sensor plugin is loaded. The model plugin is not...
I tried multiple versions of gazebo (1.4, 1.6, 1.9). Can you give me an a hint?
Hey guys,
I tried multiple versions of gazebo (1.4, 1.6, 1.9). Can you give me a hint?
Here are some code snippets: Patebinpastebin
