roslaunch gazebo_ros mars_world.launch cannot find mars.world
I have a question regarding the directory structure expected by gazebo_ros when launching it using roslaunch.
I am using ROS Groovy, with Gazebo 1.9 and gazebo_ros_pkgs built from source.
I have a catkin workspace with gazebo_ros, where I have copied the following launch file (into ~/gazebo_src/catkin_ws/src/gazebo_ros_pkgs/gazebo_ros/launch).
<launch> <include file="$(find gazebo_ros)/launch/empty_world.launch"> <arg name="world_name" value="mars.world"/> <arg name="paused" value="false"/> <arg name="use_sim_time" value="true"/> <arg name="gui" value="true"/> <arg name="debug" value="false"/> </include> </launch>
I need to keep the mars.world in a separate folder (internal/project repository) - ~/faster_dev/branches/yn/gazebo/plugin - which I have added to GAZEBO_RESOURCE_PATH. However when I try to launch gazebo with the command "roslaunch gazebo_ros mars_world.launch" I get the error that mars.world cannot be found.
I know that the mars.world works when I launch it with gazebo ("gazebo mars.world").
My environment variables are: env | grep GAZEBO GAZEBO_MODEL_PATH=:/home/yn/faster_dev/branches/yn/gazebo/models: GAZEBO_RESOURCE_PATH=/home/yn/local/share/gazebo-1.9:/home/yn/local/share/gazebo_models:/home/yn/faster_dev/branches/yn/gazebo/plugin:/home/yn/faster_dev/branches/yn/gazebo/models GAZEBO_MASTER_URI=http://localhost:11345 GAZEBO_PLUGIN_PATH=/home/yn/local/lib/gazebo-1.9/plugins:/home/yn/faster_dev/branches/yn/gazebo/plugin/build:/home/yn/faster_dev/trunk/gazebo/plugin/build GAZEBO_MODEL_DATABASE_URI=http://gazebosim.org/models
The relevant folders are gazebo_ros: ~/gazebo_source/catkin_ws/src/gazebo_ros_pkgs/gazebo_ros models: ~/faster_dev/branches/yn/gazebo/models (contains a databse.config and a number of models in subfolders) world file: ~/faster_dev/branches/yn/gazebo/plugin launch file: ~/gazebo_source/catkin_ws/src/gazebo_ros_pkgs/gazebo_ros/launch
Does anyone have any ideas why this could be giving me an error even though the world file path is correct (relative to GAZEBO_RESOURCE_PATH)?
I guess I could include "~/faster_dev/branches/yn/gazebo/plugin" in my global path, but I'd rather avoid this if possible..
Thanks!
Yasho
<launch>
   <!-- We resume the logic in empty_world.launch, changing only the name of the world to be launched -->
    <arg name="world_name" value="mars.world"/>  <!-- Note: the world_name is with respect to GAZEBO_RESOURCE_PATH environmental variable -->
</launch>
</launch>
My environment variables are: are:
env | grep GAZEBO
The relevant folders are are
Thanks!
Yasho
I have a catkin workspace with gazebo_ros, gazebo_ros, where I have copied the following launch file (into ~/gazebo_src/catkin_ws/src/gazebo_ros_pkgs/gazebo_ros/launch).~/gazebo_src/catkin_ws/src/gazebo_ros_pkgs/gazebo_ros/launch).
<launch>
</launch>
I need to keep the mars.world in a separate folder (internal/project repository) - ~/faster_dev/branches/yn/gazebo/plugin ~/faster_dev/branches/yn/gazebo/plugin - which I have added to GAZEBO_RESOURCE_PATH. GAZEBO_RESOURCE_PATH. However when I try to launch gazebo with the command "roslaunch "roslaunch gazebo_ros mars_world.launch" mars_world.launch" I get the error that mars.world cannot be found.
env | grep GAZEBO
Does anyone have any ideas why this could be giving me an error even though the world file path is correct (relative to GAZEBO_RESOURCE_PATH)?GAZEBO_RESOURCE_PATH)?
I guess I could include "~/faster_dev/branches/yn/gazebo/plugin" "~/faster_dev/branches/yn/gazebo/plugin" in my global path, but I'd rather avoid this if possible..
Thanks!
Yasho
