Cannot find gazebo_ros plugins after update from 1.9.4 to 1.9.5
I just updated gazebo-prerelease through ubuntu(12.04) update manager from 1.9.4 to 1.9.5 and now gazebo cannot find the gasebo_ros plugins which were working well till now.
Error [Plugin.hh:127] Failed to load plugin libgazebo_ros_gpu_laser.so: libsdf.so.1: cannot open shared object file: No such file or directory
Error [Plugin.hh:127] Failed to load plugin libgazebo_ros_diff_drive.so: libsdf.so.1: cannot open shared object file: No such file or directory
These were the only plugins I was using for you. I did a search for the plugins and found them in the ros simulator_gazebo stack for some reason. Adding them, to GAZEBO_PLUGIN_PATH doesnt solve the issue either.
These were the only plugins I was using for you. I did a search for the plugins and found them in the ros simulator_gazebo stack for some reason. Adding them, to GAZEBO_PLUGIN_PATH doesnt solve the issue either.either.
ROS: Groovy
ROS: Groovy
