Installing Gazebo 1.9 on ROS Groovy
Today I wanted to update my installed gazebo (version 1.8.6) to 1.9. First I uninstalled the local installed version. Then I installed the Pre-compiled binaries on Ubuntu 12.04 following these steps: http://gazebosim.org/wiki/1.9/install
No I want to install the gazebo_ros_pkgs too (http://gazebosim.org/wiki/Tutorials/1.9/Installing_gazebo_ros_Packages) but there occurred some issues:
1) When I call after the Installation rosdep update the following output is printed:
reading in sources list data from /etc/ros/rosdep/sources.list.d
Hit https://github.com/ros/rosdistro/raw/master/rosdep/osx-homebrew.yaml
Hit https://github.com/ros/rosdistro/raw/master/rosdep/gentoo.yaml
Hit https://github.com/ros/rosdistro/raw/master/rosdep/base.yaml
Hit https://github.com/ros/rosdistro/raw/master/rosdep/python.yaml
Hit https://github.com/ros/rosdistro/raw/master/rosdep/ruby.yaml
Hit https://github.com/ros/rosdistro/raw/master/releases/fuerte.yaml
Ignore legacy gbpdistro "groovy"
Ignore legacy gbpdistro "hydro"
Query rosdistro index https://raw.github.com/ros/rosdistro/master/index.yaml
Add distro "groovy"
Add distro "hydro"
updated cache in /home/alex/.ros/rosdep/sources.cache
...and rosdep check --from-paths . --ignore-src --rosdistro groovy:
All system dependencies have been satisified
ERROR[effort_controllers]: resource not found [control_msgs]
What does this error mean?!
2) When I call now catkin_make in may workspace, the following errors occurred:
CMake Error at /opt/ros/groovy/share/catkin/cmake/catkinConfig.cmake:72 (find_package):
  Could not find a configuration file for package control_msgs.
  Set control_msgs_DIR to the directory containing a CMake configuration file
  for control_msgs.  The file will have one of the following names:
    control_msgsConfig.cmake
    control_msgs-config.cmake
Call Stack (most recent call first):
  ros_controllers/effort_controllers/CMakeLists.txt:19 (find_package)
and
-- Configuring incomplete, errors occurred!
make: *** [cmake_check_build_system] Error 1
Invoking "make cmake_check_build_system" failed
So what can I do to remake Gazebo working with ROS Groovy?! Do I have to update to ROS Hydro?!
Thanks for your help :)
