Could not clear body wrenches
I am trying to clear body wrenches while following the tutorials in ROS for an object. Upon application of the body wrench, the object starts rotating. However, issuing the clear_body_wrenches service call does not clear them.
$ rosrun gazebo spawn_model -file desknog.sdf -gazebo -model desk -z 1
loading model xml from file
[INFO] [WallTime: 1355416257.896005] [0.000000] waiting for service /gazebo/spawn_gazebo_model
spawn status:  SpawnModel: successfully spawned model
$ rosservice call gazebo/apply_body_wrench '{body_name: "desk::desk6" , wrench: { torque: { x: 0.04, y: 0 , z: 0 } }, start_time: 10000000000, duration: 1000000000 }'
success: True
status_message: ''
$ rosservice call gazebo/clear_body_wrenches '{body_name: "desk::desk6"}'
The output from the terminal running gazebo reads:
Msg Waiting for master.[ INFO] [1355416249.217083040]: waitForService: Service
Msg Connected to gazebo master @ http://localhost:11345
[ INFO] [1355416251.158477063, 0.160000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1355416251.196082250, 3.310000000]: Starting to spin physics dynamic reconfigure node...
LightListWidget::OnLightMsg
[ INFO] [1355416263.447845715, 889.273000000]: ApplyBodyWrench: reference_frame is empty/world/map, using inertial frame, transferring from body relative to inertial frame
The gazebo model file (desknog.sdf) reads:
<gazebo version='1.0'>
  <model name='desk6_model' static='0'>
<origin pose='0.000000 0.000000 0.000000 0.000000 -0.000000 0.000000'/>
<link name='desk6' gravity='0' self_collide='0' kinematic='0'>
  <origin pose='0.000000 0.000000 0.375000 0.000000 -0.000000 0.000000'/>
  <inertial mass='10.000000' density='1.000000'>
    <inertia ixx='1.000000' ixy='0.000000' ixz='0.000000' iyy='1.000000' iyz='0.000000' izz='1.000000'/>
  <collision name='desk6top_geom' laser_retro='0.000000'>
    <origin pose='0.000000 0.000000 0.750000 0.000000 -0.000000 0.000000'/>
      <box size='0.750000 1.500000 0.100000'/>
    <surface>
      <friction>
        <ode mu='-1.000000' mu2='-1.000000' fdir1='0.000000 0.000000 0.000000' slip1='0.000000' slip2='0.000000'/>
      </friction>
      <bounce restitution_coefficient='0.000000' threshold='100000.000000'/>
      <contact>
        <ode soft_cfm='0.000000' soft_erp='0.200000' kp='100000000.000000' kd='1.000000' max_vel='100.000000' min_depth='0.001000'/>
      </contact>
    </surface>
  <visual name='desk6top_geom_visual' cast_shadows='1' laser_retro='0.000000' transparency='0.000000'>
    <material script='Gazebo/Green'/>
  <collision name='desk6leg_geom' laser_retro='0.000000'>
      <box size='0.650000 1.300000 0.700000'/>
    <surface>
      <friction>
      </friction>
      <contact>
      </contact>
    </surface>
  <visual name='desk6leg_geom_visual' cast_shadows='1' laser_retro='0.000000' transparency='0.000000'>
    <material script='Gazebo/Red'/>
</model> </gazebo>
Why does my model not stop spinning?
success: True
status_message: ''
    <surface>
      <friction>
      </friction>
      <contact>
      </contact>
    </surface>
    <surface>
      <friction>
      </friction>
      <contact>
      </contact>
    </surface>
</model> </gazebo>
