launching urdf model from Gazebo1.7.6+ROS Fuerte
I am trying to spawn any models through Gazebo1.7.6+ROS Fuerte. But gazebo does not spawn anything. Here is my sequence.
1) roscore 2) roslaunch gazebo_worlds empty_world.launch 3) rosrun gazebo spawn_model -file pwd/desk1.model -gazebo -z 1 -model box
From (3), just waiting with following message, [INFO] [WallTime: 1356233674.397032] [0.000000] waiting for service /gazebo/spawn_gazebo_model
From (2), I got ... logging to /home/pidi/.ros/log/d4a6155e-4cae-11e2-ba92-9c4e36943400/roslaunch-pidi7-8753.log Checking log directory for disk usage. This may take awhile. Press Ctrl-C to interrupt Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://pidi7:47191/
SUMMARY
PARAMETERS * /rosdistro * /rosversion * /use_sim_time
NODES / gazebo (gazebo/gazebo) gazebo_gui (gazebo/gui)
core service [/rosout] found Exception AttributeError: AttributeError("'_DummyThread' object has no attribute '_Thread__block'",) in <module 'threading'="" from="" '="" usr="" lib="" python2.7="" threading.pyc'=""> ignored process[gazebo-1]: started with pid [8773] Gazebo multi-robot simulator, version 1.2.5 Copyright (C) 2012 Nate Koenig, John Hsu, and contributors. Released under the Apache 2 License. http://gazebosim.org
Exception AttributeError: AttributeError("'_DummyThread' object has no attribute '_Thread__block'",) in <module 'threading'="" from="" '="" usr="" lib="" python2.7="" threading.pyc'=""> ignored process[gazebo_gui-2]: started with pid [8780] Gazebo multi-robot simulator, version 1.2.5 Copyright (C) 2012 Nate Koenig, John Hsu, and contributors. Released under the Apache 2 License. http://gazebosim.org
Warning [parser.cc:358] Converting a deprecatd SDF source[/home/pidi/workspace/simulator_gazebo/gazebo_worlds/worlds/empty.world]. Version[1.0] to Version[1.2] Please use the gzsdf tool to update your SDF files. $ gzsdf convert [sdf_file] Warning [Converter.cc:191] Deprecated SDF Values in original file: <background rgba="0.5 0.5 0.5 1" <="" p="">
Warning [Converter.cc:191] Deprecated SDF Values in original file: <background< p="">
Msg Waiting for master[ INFO] [1356232460.536994870]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
Msg Connected to gazebo master @ http://localhost:11345 Msg Waiting for master Msg Connected to gazebo master @ http://localhost:11345 Warning [parser.cc:374] Gazebo SDF has no <gazebo> element in file[data-string] Error [World.cc:1190] Unable to read sdf string
As long as I comfirmed through rosservice list, '/gazebo/spawn_gazebo_model' service exists. I also tried many other urdf files, but results are same.
I also followed http://www.ros.org/wiki/simulator_gazebo/Tutorials/SpawningObjectInSimulation, but it was also same.
Does anybody have idea?
From (3), just waiting with following message, message,
From (2), I got got
SUMMARY
From (2), I got
<1GB. started roslaunch server http://pidi7:47191/
SUMMARY
http://pidi7:47191/ SUMMARY ======== PARAMETERS * /rosdistro * /rosversion * /use_sim_time
/use_sim_time NODES / gazebo (gazebo/gazebo) gazebo_gui (gazebo/gui)
(gazebo/gui) ROS_MASTER_URI=http://localhost:11311 core service [/rosout] found Exception AttributeError: AttributeError("'_DummyThread' object has no attribute '_Thread__block'",) in <module 'threading'="" from="" '="" usr="" lib="" python2.7="" threading.pyc'=""> 'threading' from '/usr/lib/python2.7/threading.pyc'> ignored process[gazebo-1]: started with pid [8773] Gazebo multi-robot simulator, version 1.2.5 Copyright (C) 2012 Nate Koenig, John Hsu, and contributors. Released under the Apache 2 License. http://gazebosim.org
http://gazebosim.org Exception AttributeError: AttributeError("'_DummyThread' object has no attribute '_Thread__block'",) in <module 'threading'="" from="" '="" usr="" lib="" python2.7="" threading.pyc'=""> 'threading' from '/usr/lib/python2.7/threading.pyc'> ignored process[gazebo_gui-2]: started with pid [8780] Gazebo multi-robot simulator, version 1.2.5 Copyright (C) 2012 Nate Koenig, John Hsu, and contributors. Released under the Apache 2 License. http://gazebosim.org
http://gazebosim.org Warning [parser.cc:358] Converting a deprecatd SDF source[/home/pidi/workspace/simulator_gazebo/gazebo_worlds/worlds/empty.world]. Version[1.0] to Version[1.2] Please use the gzsdf tool to update your SDF files. $ gzsdf convert [sdf_file] Warning [Converter.cc:191] Deprecated SDF Values in original file: <background rgba="0.5 rgba='0.5 0.5 0.5 1" <="" p="">
1' Warning [Converter.cc:191] Deprecated SDF Values in original file: <background< p="">
<background Msg Waiting for master[ INFO] [1356232460.536994870]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
waiting... Msg Connected to gazebo master @ http://localhost:11345 Msg Waiting for master Msg Connected to gazebo master @ http://localhost:11345 [ INFO] [1356232462.211541328, 0.001000000]: joint trajectory plugin missing <updateRate>, defaults to 0.0 (as fast as possible) [ INFO] [1356232462.234273210, 0.022000000]: waitForService: Service [/gazebo/set_physics_properties] is now available. [ INFO] [1356232462.262465099, 0.050000000]: Starting to spin physics dynamic reconfigure node... Warning [parser.cc:374] Gazebo SDF has no <gazebo> element in file[data-string] Error [World.cc:1190] Unable to read sdf string
string
